Print cartridge cradle installation
HP photosmart 7350 print cartridge cradel installation
How does the color catrigde for ip 1800 doing?
Posted on May 16, 2009
SOURCE:
I have an hp photoshop 7350 with an error message of "Print cartridge cradle is stuck". Can you help?
Good day!Try to see if there is a foreign object that made it stucked..try cleaning the ink in the carrier of your cartridges..
feel free to ask..
mastergani
Mar 26, 2010 | HP PhotoSmart 7350 InkJet Printer
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
My HP 7350 Prints Almost Nothing
You should try going into the properties and running the head cleaning that will fix ya right up
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 27, 2009 | HP PhotoSmart 7350 InkJet Printer
Hp photosmart 7350-cannor print from emails or any
Your printhead is either clogged or not working. There should be a self cleaning program built in to the printer. Run this 4 or 5 times. If the unit still doesn't print you can either clean it yourself with Q-tips and isopropyl alcohol, or take it to your local HP printer repair center. If you printer is still under warranty I would advised having them check it.
Jul 15, 2009 | HP PhotoSmart 7350 InkJet Printer
Get error message on my HP Photosmart 7760 that "Print cartridge cradel stuck. Clear jam then press okay"...but there is no jam. :( Help...thanks.
jam not on the paper but, check the space where the printhead slides on, see if there is something blocking the path
Jun 26, 2009 | HP PhotoSmart 7760 InkJet Printer
Cartridge failed
I just purchased new hp cartidges and I still get error massage cartidge #57 needs to be replaced.
The line on the printing at the end or far right of the sentence (like the last 3 or 4 words are faded)
this is for hp 7550 photosmart
Oct 29, 2008 | HP PhotoSmart 7350 InkJet Printer
Printer cartridge cradle is stuck-hp photosmart 7350
I just had the same problem...and this is what I did to get it working...
Turn off your printer. Open the top. Push the cartridge thingie off to the side (if possible) and then take QTips and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
Should run after that.
Dec 01, 2007 | HP PhotoSmart 7350 InkJet Printer
Print cartridge cradle struck
packing material like spanch remove form printer
Print cradel CRASHES!! into the right side of my printer
There is a thin, clear plastic strip that guides the carriage & stops it from slamming like that. it is broken sadly. try getting one from ebay and switching it out. We got ours for like $13 shipped
Sep 03, 2007 | HP PhotoSmart 7760 InkJet Printer
Open Questions:
168 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
