Question about Kitchen Ranges
No flame but ignitor still works
I have a 31fa-2kx magic chef oven. (25 years old) the ignitor glows but no flame. only the smell of gas. is it time for a new oven or can i fix this one a get a couple more years.
  • 67 Answers
The ignitor is bad, It's not pulling enough amps to fully open the valve. Still consider replacement, it's lived it's life
Posted on May 18, 2009
I have a magic chef ovan/mic unit, when I press the bake option and set the temp the igniter goes on but the gas does not kick in. model # 54FN-5TKVWM
even though the ignitor glows it doesn't mean it's good it opens the gas valve by amps not just because it glows,if you turn on the stove and when you see it glow if the flame doesn't ignite within 40 to 50 seconds you have a bad ignitor.if you leave it alone for a few minutes does the flame ignite?the only other thing it could be is a bad gas valve but most likely it will be the ignitor
Sep 25, 2011 | Magic Chef Ovens
Magic Chef oven won't lite. The ignitor glows red hot but no flame. After about 10 minutes of being on I start to smell gas. Not a strong smell but its in the air. I'm thinking gas valve. I did a...
The problem with your oven is that ignitor is weak and not drawing enough amprage to open the gas valve, the gas you smell was since the ignitor does come on it allowed the gas valve to open a wee bit but since ignitor is weak it wont allow gas valve to open fully. I know you going to doubt that what i'm telling you is correct, i base my diagnosis on my 30 years experience as a appliance repair technician.Replace ignitor and enjoy your baked meal
Gene
Jul 30, 2011 | Magic Chef 9122 Gas Single Oven
No gas flow to oven, glow bar ignites no flame no smell of gas. safety gas safety valve was replaced
With the glow bar going and no gas smell that means you have a good circuit from control to valve and glow bar. For that glow bar to work it must change in resistance. If it is weak it won't change enough resistance to make the gas valve bi-metal open. Also the gas safety valve does not come preset and usually is bottomed out all the way for propane. You must adjust the orifice to aprox the same height as the old one to get the propah gas output for natural gas.
if your old valve did not leak and has continuity between the terminals it is fine. The ignitor/glowbar is weak. If it is dim orange that is usually a way to tell. Bumping the stove makes the bi-metal come on also is a sign of a weak glowbar
Jul 14, 2011 | Magic Chef Ovens
Oven ignitor glows bright red, but oven will not light. No smell of gas.
our ignitor glowed but still was not working right. it has to get to a certain temp before the gas valve will open. try changing it out. fairly inexpensive.
Jun 19, 2010 | Magic Chef 9122 Gas Single Oven
What amps is the ignitor supposed to pull to engage the gas valve in a magic chef gas oven? The top burner all work fine.
I was once told it was 3 to 4 amps but most techs just replace the ignitor and test the machine for 3 or 4 cycles. if it does not fix the problem then we change the valve. It's hard to put your amp probe in the oven that is going to start shooting out a flame.
Most techs can look at how the ignitor is glowing and tell if it's bad or good by how bright it glows.
As always make sure you unplug the machine befor changing a part.
Jan 11, 2010 | Magic Chef 9112 Gas Double Oven
Oven stopped working
No, that is a top burner valve. Most likely the igniter is bad, part # 12400035. The only way to test it is with an ammeter; it must draw a minimum of 3.3 amps to cause the valve to open. Oven valve part # 7501P133-60. These go bad as well, but not nearly as often. If you are going to take a risk, try the igniter first. Available for $40 at www.timerking.com and elsewhere. Hope this helps!
Jan 28, 2009 | Magic Chef Ovens
Leak Safety Valve Magic Chef Oven?
that could be rigth only if that ignitor is good,,,that ignitor has to glow bright orange,,if its weak,,which it sounds like to me,,the gas will take a long time to ignitor,,or dont ignite and you smell a wee bit of gas,,,onthejob
Jan 08, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic Chef Oven won't light
Your oven bake ignitor is becoming defective. Even though it is glowing, the resistance is not great enough to "pop" the gas valve open and is slowly seeping gas into the oven cavity. With a strong ignitor, the oven should light within 30-45 seconds. Because this is a gas oven, I DO NOT RECOMMEND FIXING IT YOURSELF. Call an experienced technician.
Sep 27, 2007 | Ovens
Kitchen Ranges Logo
136 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
