Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
OUT OF BALANCE SPIN CYCLE
I HAVE A WHIRLPOOL LSQ9549LGO WASHER THAT IS TOTALLY OUT OF BALANCE DURING SPIN CYCLE. I HAVE LEVELED IT AND CHECKED THE SPRINGS BUT CAN'T GET IT TO SPIN WITHOUT THE UNIT SHAKING AND ALMOST WALKING OUT OF THE ROOM. COULD IT BE THE DRUMS SPRINGS ARE SO WEAK THEY DO NOT SUPPORT IT ENOUGH TO BALANCE IT? YOUR HELP IS MOST APPRECIATED.
  • westglen May 12, 2009
    Thank you for your suggestion. i will check and report back in a day or so.
  • 62 Answers
Check you base pads and plate pads,...also make sure you have a total of 5 springs connecting to the bottom of the tub. Make sure they are all there.
Posted on May 12, 2009
I have a whirlpool cabrio model wtw6600sw0 ans my washer tub is unbalanced and rocks bad. i have leveled the machine and evenly distributed the load! could there be something wrong with the tub or...
after you leveled the washer did you turn the locking nuts on the legs up against the bottom of the washer cabinet to keep the legs from vibrating back out of level?if you dont lock them they will change height during spin
May 06, 2012 | Washing Machines
Whirlpool duet wfw9550 keeps getting out of balance on spin cycle i have re-leveled the washer 4 times now and it keeps going crazy on spin cycle how do i fix
Their is a auto balance circuit in the machine. it a sensor, it will adapt the machine... you may have a failure in this machine....
Dec 19, 2010 | Whirlpool Duet WFW9550 Washer
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Heelo, during the spin cycle the washer stops and
Water not draining from the tub. Check for hose crimp ir clog. Here is your manual codes on page 19.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/8566930.pdf
Aug 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer runs quietly steadily except during spin cycle, when it tries to walk out the door. Have leveled the machine,even strengthened and leveled the floor.
Does it always do this or does it only happen when the load is unbalanced? In other words once this starts to happen can you lift the lid and rearrange the clothes within to balance the load and try again.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Feb 18, 2009 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
578 people viewed this question
Dan Webster
Dan Webster
Sal De
