Question about Dryers
Breaker keeps tripping, dryer will not come on due to this
The top of the dryer (Kenmore HE2 elite) was rubbing on the barrel. I solved the problem by removing the top and bent it back. Now the breaker keeps tripping and the unit won't stay on. What could have happened?
    Genius:
  • Dryers Master
  • 1,198 Answers
Take it apart again and look for a pinched wire at whatever panels that you removed.
Posted on May 12, 2009
My kenmore elite oasis washing machine stopped mid wash there is no power at all. Model #110.28092700
first plug a lamp or something you know works into the outlet.if lamp does'nt work,check the breaker at breaker panel.If that is not tripped,it may be the onoff switch,or timer on machine.
Sep 27, 2014 | Kenmore Oasis HT High-Efficiency 4.6 cu....
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Kemore elite dryer keeps knoting the breaker
Here is a tip that I wrote that will help you ti find out why the circuit breaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Oct 03, 2010 | Kenmore Dryers
I have a sears kenmore gas dryer model 87592820 it keeps blowing the breaker. It was running about 1 min. then a spark flew out and it tripped the breaker. When I reset the breaker it continues to trip it....
This sounds like you have a wire that rubbed through and is shorting out...
open up the back or where you saw the sparks come from and you will easily see the burnt mark...then you can fix it...
Do not keep trying the breaker... it is tripping to protect you and keep you safe.
heatman101
Sep 28, 2010 | Dryers
Dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
Kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
kenmore elite won't start, Solve kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on... (More) kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
Jul 03, 2009 | Kenmore 63942 Dryer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore HE2 door bellow
he 2 are a little similar to all H E washer ,, it has spring clamps (2) remove and install them same way
Dec 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite keeps tripping circuit breaker and small flash
Hello jaybebo84,
May be coincidental that you had a short circuit ocurr in the back panel after your wife dusted but the problem is that you now have a short circuit which will trip the breaker. If you can unplug it and slide it out to gain access to the back panel, remove the cover and look for carbon or flash burn on some of the components in that area. Usually when you get an arc like that the evidence of the component is pretty easy to identify. You may see some carbon or equivalent on a component which once located, could simply be removed and replaced. Sears usually has exploded views drawings of all their appliances and you may be able to get a copy from the store service area. Good Luck..
Regards,
Rick
Nov 25, 2008 | Whirlpool GEW9250 Electric Dryer
Tripping circuit breaker
if the dryer trips the breaker right away its a problem with the dryer if its after a while its the breaker. call an electrician to make sure the wires are secured tight to the breaker and the breaker is rated correctly. i can almost guarantee its the breaker.
Dec 18, 2006 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
95 people viewed this question
Top Dryers Experts
