It will do the wash cycle, but it wont do the rince & spine cycle.
It will do the wash cycle but wont do the rince & spine cycle.
  • 62 Answers
It is probable your lid switch.
Posted on May 12, 2009
Fisher Paykel washer won't spin and drain. Any solution? Error looks like no E AP
possible answer for you see the link after reading Error/Fault code 00000101. (The value is 5.) It wasnt draining the water out at the rince cycle. I saw comments on fixya.com that others with the same problem found clothing between the outer bowel & the inner bowel or an item such as a necklace chain or hairclip jamming up the propeller..... (Two days later, see part 2....) I just fixed this F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.) Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!! Fisher Paykel GW612 Not rincing spinning part 1
Mar 15, 2018 | Fisher Washing Machines
Will not rince at end of wash cycle
If ur machine have additives cycle, check whether the solenoid valve (for opening water inlet to the additives' tray) is working or not. You can check this by listening to the sound of water during additive cycle. If it is not working, you have to replace the water inlet valve unit.
Nov 19, 2012 | Bosch Washing Machines
Wont finish cycle there is a F code
Remove the bottom panel.a6ecc58.jpg The tech sheet with fault codes and diagnostics is behind the motor control unit,white box to left.448bb9b.jpg Clean out the pump filter and housing,7d13dce.jpg maybe that will helpc654f05.jpg
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't agitate
Hiya,
these noices are often caused by a water issue the rince cycle is a cold water intack so i would surgest turning of the cold water at the mains or shut off valve then disconnect your cold intack hose & check for any clogging it could be a build up of lime scale or lint & the simple removal & cleaning of this hose could fix your problem.. alternativly ensure the cold water supply is turned to the on position to allow the water trough to rince
Hope this helps
Apr 22, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
The rinse and spin cycles never end
I have seen this often on another brand. Once it starts malfunctioning on the rince/spin cycle, the boars needs replacement.
Nov 13, 2009 | Fisher Paykel EcoSmart GWL15
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
