Question about Sharp AR208s copier AR208s All-In-One Printer
How do I put developer in a ar208s sharp copier
I just got a new ar208s sharp copier. I bought developer and a toner cartridge. Where does the developer go?
    Problem Solver:
  • 14 Answers
The developer comes in a bag and is poured into the developer unit which is the unit that the toner unit slides into. You should have a screw to loosen to slide the developer unit out. It has a silver magnetic roller that will be visible. There will be an open slot on top of this unit to carefully pour the developer contents into keeping it level. Reinstall and secure the holding screw. install your toner and test. I hope that this helps. Usually a service tech will set this up for you before you see it.
Posted on May 12, 2009
I' ve a problem with copier ar 5516. i need information about using of developer. where i must to put the developer? the toner AR-021FT IS COMPATIBLE WITH THIS COPIER?
yes ar021FT toner compatible for your 5516. when replacing the developer:1) pull out the toner cartridge,2) pull out developing unit with 1 screw (blue),3) in developing unit remove 2 screws (blue) to open its top cover,4) drain d unit and replesnish with new developer. do procedure 4 to 1 to return. Good luck.
May 22, 2011 | Sharp AR-5320 Black and White Copier
AR 5127 error code is F2-02 solution
1,Check the coupling gears @ the developer tank if defective.
2.Pour out developer from the tank and check for strange particles which can prevent free movement of rollers in the
Apr 10, 2011 | Sharp AR208s copier AR208s All-In-One...
My copier sharp5316 has error code of f2 pls help me on this.
That is normall a defective developer unit chip, you may have to replace the chip on the developer unit or the developer unit itself.
Aug 17, 2010 | Sharp AR-5316 Advanced Digital Imager...
Void copy
Have replaced the developer? I don't remember if the copier toner is the developer unit. Did you just put a new toner in. If so, you may have a defective cartridge.
Jul 30, 2010 | Sharp AR-153E Copier
My sharp ar5316e show f2 04 solve this
clear the memory of the machine, change the destination of the toner or fixe in a new toner crum or also known as toner sensor
Jul 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
Blank copies on an ar208s sharp copier
Inside this machine has 3 sections. Toner cartridge, developing unit and drum unit. First pull out the toner cartridge then you will see a blue anodized screw, loosen this screw then pull this section ( developing unit ), if there's already toner inside the chamber, clean it and pour the all the developer into the chamber then put back the developing section, tighten the blue screw and install the toner cartridge.
May 12, 2009 | Sharp AR208s copier AR208s All-In-One...
Newly installed Sharp AR-5320E not copying
That is because you need to put in some developer. This acts as a carrier for the toner. AR202ld is what you need
Nov 24, 2008 | Sharp AR-5320 Black and White Copier
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Adding developer
If you buy a new toner cartridge the developer is already in it.
Are you mixing ink and toner to rebuild cartridges?
If your just a user, once you replace the toner cartridge you have added new ink with the developer in it.
If you are not mixing and rebuilding the toner cartridge, and installing a new one, You do not need developer.
Apr 03, 2008 | Sharp AL 1631 Copier
Sharp AR208s copier AR208s All-In-One Printer Logo
88 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
