Question about Maytag MDB7100AWB Dishwasher
Maytag MDB9100AWW Dishwasher
Im having problems starting my Maytag MDB9100AWW Dishwasher. I had to take it apart to clean out debris left inside by years of use by kids not doing a prerinse before putting the dishes in. Once all cleaned out and put back together , I got about ten uses out of it and then it just stop working. That is to say when you load it and shut the door, and push the buttons nothing happens. I have opened and closed the door , pushed and pulled and played with buttons and got it to work a couple times. Making me believe there is something wrong with the door safety switch or it needs to be adjusted. Either way , can you give me some clue is to where the safety switch is located so as to adjust it or how to start it up if that is not what you think is the problem.
  • iris4sun Feb 25, 2009
    i think i may have the same problem. can use a screwdriver. after power is cut off, do you go into control board and clean out moisture?
    dishwasher will not turn on. for a long time i used the auto clean cycle. when i switched it was hard to press the button and get it to wash. other times it didn't want to take a different setting so then i'd go back to the auto. then i noticed pushing a button harder or at a lower angle seemed to work. not it will not turn on at all in any cycle. it will be 8 yrs old in august.
  • 3 Answers
We have this same model. Right under the 5 yr warranty mark, the control panel started going "funny". Some of the buttons stopped working, then more. We could finally get it working only in one mode. I was certain it was the control board, which I replaced under warranty just in time.
This lasted another year, until moisture began appearing under the number window and the left side button set stopped working. Now the right side is gone, except for the delay-start button.
I believe moisture is getting into the control board and frying it, either slowly or quickly. If you are seeing similar problems where buttons seem to stop working, it is PROBABLY the control board. It is a relatively easy home repair if you know your way around a screw driver.
Posted on Dec 31, 2007
Ge dishwasher not cleaning dishes and leaving debris behind
check for corrosion or debris in the water jets clean if necessary
Mar 11, 2012 | Dishwashers
My Tappan Quiet Clean I is not cleaning very well at all. I have had it for almost 13 years. In the past year or so, it has left me very frustrated. I hate to buy a new one because it does run and clean...
You may not have to get a new dishwasher just yet. When I see things like this, the most common problem I find is clogged jets in the spray arms. Try removing the spray arms and clearing any debris from the holes. I hope this helps.
Feb 14, 2011 | Tappan MDB531RF Dishwasher
Dirty dishes on Maytag 24 inch dishwasher, model no MDBH940AWS, Dishes have caked on gunk on the glasses after washing. The gunk is usually at the bottom of a glass (which is in the dishwasher upside...
This dishwasher has a circular filter path under the bottom plate - 6 screws - that can become filled inside with debris - you can remove it and wash it out with a garden hose.. Paul
Nov 20, 2010 | Maytag 24 in. MDBH940AWS Built-in...
Maytag eq plus dishwasher- how to disassemble bottom spray arm?
its probably leaving water in it and is clogged in the elecric pum or drain hose. somethins the pump has a rubber flap that will become lodged in the outlet port. this will cause dirty water to be left in the machine because of a slow drain. start by looking at the volume of water coming into garbage disposal where drain hose hooks up.
Aug 01, 2010 | Maytag Dishwashers
Maytag dishwasher model mdb9100aww will not turn on I checked and reset the breaker and also checked to see if any wires were loose
did you check the door lock mechanism? if it is not locking the door properly, the machine will register an unlocked door situation and will not start. 250
Nov 07, 2009 | Maytag MDB9100A Dishwasher
Want to know how to clean the arms
here is a breakdown of the inside of the machine. if the spray arm is not plugged, check the filter screen for debris. also check to make sure the wash impeller is not bro250ken. hope this helps a little.
Oct 24, 2009 | Maytag MDB7100AWB Dishwasher
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Dishwasher Will Not Rinse
You are probably not getting enough water into the machine. Replace water inlet valve (solenoid valve) and this should solve the problem.
Nov 13, 2008 | Maytag MDB7100AWB Dishwasher
Racks corroding.
Check on Ebay. I just entered this to check for you. maytag dishwasher racks" and there were several on there. One was universal and could be used with 40 different model numbers.
Oct 25, 2007 | Maytag MDB9100A Dishwasher
Maytag MDB7100AWB Dishwasher Logo
1,152 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
