Question about Toshiba 53H71 53 in. Rear Projection Television
Touch Focus Error
I have a 42" rear projection Toshiba that for whatever reason is displaying a " Touch Focus Error" error message after the function completes. The picture is OK on all stations.
  • jasonsekhon Mar 29, 2008
    Touch focus error..does not go away. TV shows out of focus picture
  • dtoavs50 Aug 26, 2008
    My picture is not OK, but I can't seem to align the guns.
    Genius:
  • 1,694 Answers
Even if the pix appears to be "OK", the internal convergence
alignment (in servicer mode) must be accurate within certain
parameters for the Touch Focus function to complete w/o error.
Adjustments should be done in "Full" mode,both HD & regular
signal.
Posted on Oct 13, 2007
I have a rear projection Toshiba 42 inch and cannot get convergen
Sounds like convergence should replace chips marked Q 751 and Q752 part numbers ( stk392-110) check restors 1.8 ohms 1 watt rateing should be marked on board as R 7721 and so on, should more than one in the area of the ic. Look to see if there is some small fuses in the area also. They dont look like a normal fuse may be yellow or green black marked F on board around the ics these fuses are called pico fuse.
Feb 01, 2010 | Toshiba 42H81 42" Rear Projection...
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
42H83 auto touch focus ERROR and hyper board bad?
repleace cap for $ 80 , thats good , the error is do to comvergenge aligment
May 03, 2008 | Toshiba 42H83 42" Rear Projection...
Still green
go In service convergence mode and try to adjust red and green if you cant then it's convergance amp ic's
if you can adjust them so they align up try doing a touch fous after that,.
Dec 16, 2007 | Toshiba 42H81 42" Rear Projection...
TOUCH FOCUS ERROR on Projection Toshiba TV
My 57H81 won't converge, plus I get the "touch focus error" message. I could get manual convergence of blue, but not red. Plus, during touch focus the red would not move horizontally
Nov 25, 2007 | Toshiba 57H81 57" Rear Projection...
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 23, 2007 | Toshiba 55H70 55" Rear Projection...
42H81 touch focus error
check for bad solder connections on the connvergence ics if that dont fix it then replace them
Nov 01, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
801 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
