Question about Kenmore HE2 Plus Front Load Washer
Clean water in detergent drawer in 2 compartments
The water is in the bleach and the softner compartments. Machine still works.
  • 460 Answers
Can you especify a little more.
thank you
Posted on May 12, 2009
My LG washer machine will not rinse thru the softer section in the cup, what can I do?
then the solenoid is not actuating to allow water into drawer. take top off, very easy, two screws in back, pull back, lift off. follow hose from softer cup to little round device/solenoid. check wiring. check hose, tho you would know there was a problem with hose, because you would see a water leak. replace solenoid. hope this is the issue. good luck.
Mar 02, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
GE WSXH208AWW doesn't dispense detergent, softner or bleach. Dispenser is totally dry after wash cycle.Appears no water gets to tray.
I'm having almost the same problem - the bleach & softener both will NOT dispense, but (LUCKILY) the detergent does dispense on mine, for now.
In order to get the solutions (bleach, softener, detergent) to go into the washer, the water needs to pour through the dispenser somehow. Dry means NOT working (mothmanmeg).
I need help, too!! We tried taking the drawer out & cleaning, no luck.
Apr 17, 2010 | GE WSXH208A Front Load Washer
Bleach & Fabric softner tray not working.
Remove the drawer by pushing the tab at the top of the drawer and pull it out and check for an obstruction. They regualarly plug up with gummy fabric softenener. Try washing out with hot water and reinstall
Apr 04, 2010 | Frigidaire GLTF1670A Front Load Washer
Dispenser tray removal
hi, nikoltheis! i'm not sure if we have exactly the same model, but it should be pretty close. here's what my user's manual says:
Detergent and fabric softner may build up in the dispenser drawer. Residue should be removed once or twice a month
- Remove the drawer by first sliding the safety latch to the right, then pulling the drawer out until it stops.
- Reach back into the left rear corner or the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
- Remove the insert from the bleach and fabric softner compartments.
- Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softner residue may indicate improper dilution or that more frequent cleaning is required.
- To clean the drawer opening (the empty area left behind when you remove the drawer) use a small brush to clean the recess. Remove all the residue from the upper and lower parts of the recess. (The picture shows this being done with a tooth brush.)
- Replace the insert pressing "X" to lock it in place. Return the dispenser drawer.
Jan 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Fabric softner does not disperse, a smell comes into sink.
Remove the drawer and thoroughly clean out the drawer. They usually have a syphon mechanism which gets blocked. On many, you will find a section of the softener compartment can be removed. Make sure there are no traces of old softener. The eggy smell is due to the enzymes in the detergent not being properly flushed from the machine. Check the waste water pipe is clear of debris and clean out any filters (not all machines have these) - normally under a cover at the front of the machine near the floor. While you have the detergent drawer out, it would be worth cleaning the area as it often gets clogged and covered in detergent or softener, and can block the water feed holes.
After all this cleaning, run the machine on a hot was with no detergents/softeners or laundry in it, to flush it out.
Jan 07, 2009 | Whirlpool Washing Machines
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Oct 19, 2008 | GE Energy Star WCVH6260F Front Load Washer
Water in soap holder after washing.
my washer is about 1 year old. It started leaving water in all the the compartments,soap,bleach and softner. I tried everything also. Nothing seemed to work. I finally took the hoses off the back of the machine, and the cold water hose screen was clogged up going into the machine. I cleaned all the screens and haven't had that problem again. I think there wasn't enough water pressure to flush out the containers. I dont think its gravity or suction, its water pressure. unless you get a blast of water into these compartments, there will always be water left in these containers.
Oct 27, 2007 | LG WM-2277HW Front Load Washer
Softner still in the draw
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next step !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test with a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Aug 03, 2007 | Hotpoint WF645 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
51 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
