Question about Kenmore Ovens
F3 blinks on panel
My friend has a Kenmore 4 burner gas range with electronic lite and panel, has started getting an F3 message and will sometimes automactically turn off. It happens randomly , it has no type of serial #s or any markings at all. It was in the house when they purchased it so it is at least older than 1998. They are push buttoms and a turn knob for the tempurture.
Thank you,
Cathy
  • Kenmore Master
  • 3,361 Answers
Replace the oven temperatire sensor.
Posted on May 12, 2009
F3 code on Kenmore Oven Model 911 4558810
The F3 error code indicates that the EOC (Electronic Oven Control board) senses a problem with the oven temperature sensor. You could have a defective sensor, a failed EOC or a bad wiring connection between these 2 components.
Normally, a technician is needed to diagnose and repair this type of failure. The technician would unplug the range and access the EOC in the console. He would pull the 15-pin plug from the EOC and measure the resistance between pins 12 and 13 of the plug. This would check the temperature sensor and connecting wiring. The tech should measure about 11000 ohms at room temperature (75 degrees Fahrenheit).
If this reading is good, the EOC would be the failed component and would need to be replaced.
If the resistance reading of the sensor circuit is bad, the reading would be taken directly from the leads on the temperature sensor. If the resistance reading taken directly off the sensor is bad, then the temperature sensor has failed and would need to be replaced. Otherwise, the wire harness is the failed component.
If you have a volt/ohm meter and the technical expertise to safely access and test internal components of your range as described above, you may be able to diagnose and repair the range yourself.
Feb 18, 2013 | Kenmore Ovens
How do I lift the stove top to turn off pilot model # FGF366DCB?
there isn't a pilot in it,it has an electronic spark module in it.what problem are you having?when you turn it to lite it you'll hear a clicking sound,that's the sparking that lites the gas just like you're gas grill.if you want to remove the top you have to remove the two phillips screws out of each burner head,sometimes they don't come out and you have to drill them out,if the burner isn't shutting off the gas valve could be broke or the knob could be broke,if it's clicking just unplug it and you can lite the top burners with a match or bbq clicker to lite them until you get it fixed depending on what problem you are having.if the gas won't shut off by turning the knob you'll have to shut down the gas at the valve that feeds the stove.but like i said if you want to lift the top you have to remove all the screws in the burner heads.hope this helps you out.http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Range-Parts/Model-FGF366DCB/1428/0124002?pathTaken=&prst=0&shdMod=FGF366DCB go to this site and you can look up your machine.
Sep 03, 2011 | Frigidaire Ovens
We have a Whirlpool Gas Range, model SF357PEKQ. When I start the bake feature, you can hear the gas flow, the ignitor click (about 4 times) yet there is no ignition of the gas (flame doesn't start)....
Whirlpool had some grounding issues with some of their electronic ignition ranges. Make sure your outlet is grounded first. Then you might need to make sure the bake burner itself is grounded very good against the range frame. I have put star washers between the burner and frame and tightened very tight, that sometimes helps. Also make sure the holes in the burner under the spark electrode are clear from debris. Sometimes the burning of gas leaves a residue that can stop up the holes and not let the gas flow out where the spark is hitting the burner. Hope that helps.
Aug 29, 2011 | Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Is replacing a thermocouple in an oven difficult? my oven has started cutting out after just a minute or two of being on. On closer inspection, i've noticed the wire seems to be corroded at the base of...
My Kenmore electric wall oven will not increase the heat to the desired setting. The electronic display holds at 100 degrees. Could the problem be the thermocouple or the electronic range control. The range control is hard to find, which is part # 318010701, made by Fridgidaire.
Jan 17, 2010 | Ovens
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
When using oven it beeps and displays f3
Could be one of 2 problems. Perhaps both.
Unplug the range.Access the control panel and unplug the ribbon connector from the control.
Wait 35 seconds and re-connect it.
If it continues to beep and code replace the temperature sensor.
Mar 15, 2009 | Kenmore Ovens
Unable to clear error message on panel...oven not operating
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#RET
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Spark module clicks and gas will not stay lit, flame comes on but goes out
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
thank u.................
Sep 11, 2008 | Ovens
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
