Question about Bosch Axxis WFL 2060 Front Load Washer
Washer appears to operate but drum will not turn
The washing machine has got power and appears to be going through the programme but the drum will not rotate. I suspect the carbon brushes may be at fault. but how are they changed?
Did you ever resolve the problem? My washer accts the same way
Posted on Dec 05, 2007
LE code is flashing when I try to run the machine
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jun 25, 2010 | LG WM2277H Front Load Washer
Indesit wd1030 washing machine drum not working
Your drive belt may be damaged and needs replacing
Nov 06, 2009 | Washing Machines
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Bosh washing machine won't do any programmes
If it fills then the next phase is to agitate.
To do that the motor must drive
Can you hear a whirring sound from the machine if you get close to it if so then the belt driving driving drum may have snapped.
If not then the motor brushes may have stuck or have worn out.
Does the machine programmer advance by itself or are you turning the dial
May 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
DRUM NOT SPINNING
Disconnect your washer's plug for 5 minutes or more from the wall socket. Plug in. Press "end of cycle" button for over 5 seconds, the child lock comes off.
Press it again and the child lock comes on................ If this does not work, try the pre-wash button likewise.
Nov 22, 2007 | Bosch Exxcel WFO 2264 Front Load Washer
No heat on tumble dry programme. Display flashed F 13.
You need to replace the heating element for the dryer which is positioned on top of the outer drum. Remove the top cover of the machine and locate the heater.
Nov 01, 2007 | Hotpoint Ultima WF860 Front Load Washer
My washing machine doesnt stop filling the tub when the right water level is reached, it will just continue filling and never stops filling. Can anyone suggest what is wrong and how to fix this?
Not familiar with this model. When a washing machine fills with water up to a predetermined level, it usually operates a pressure switch which will turn off the water valve, and redirect the power to the programmer, or heater, or some other stage of the programme. If there is a blockage of powder or gunge in the tube leading to the pressure switch this would prevent air from rising up the tube to operate the switch. Tom.
Feb 27, 2007 | Admiral AW22 Top Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
121 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
