Question about Apex Digital GB55HD09W 55" Rear Projection Television
TV DONT TURN ON
I have a apex hdtv model number GB55HD09W and what happens is when i plug it in i get a buzzing noise and now wen i turn it on or tyr at least the green light flashes and it sounds like it is turning on but it shuts down compleatly. at this point nothing works until i un plug it and plug it back in and then it does it all over again. what can this be? please help? what is it caused by??/????
  • 16 more comments
  • Travis Girmscheid May 12, 2009
    does any body know were i can order or buy cheaper or used apex tv parts. to be specific a apex GB65HD09W
    so do you think if i replace the power bored in it that will take care of it or no???
    well is there a prosses of elemination we can try? i did take the back off and wen it is pluged in i can hear one of those transformer things on the power bored buzzing and the other one does nothing? by transformer its the square thing with the copper wire around it and there is two of them.
    so is there a way i can test that board? or just spend the money. it was working great today but it started flickerin on and off but the sound was there then it was fine for like an hour then boom nothing
    what is b+?
    YEA I GOT A PICTURE.
    these are what i can hear buzzin the one in red buzzes but the one in yellow does nothing. the buzzing i going on wen ever the tv is pluged in.
    ok guys i was tinkering for a bit here and it seems like wen i uplug the wires that go from the power board to the other circuit board by the black thing that has the one big red wire going into it then that big red wire splits over to 3. wen i unplug this then the tv sounds like its turning on but dont and he green light stays on unless i turn the tv off. here is a pic
    im sorry but i cant veiw the picture for some reason. can you posibly email it to me VIA girmscheid_family_2008@yahoo.com
    i can see the pic now. so how do i test this? what do i do
  • Anonymous May 12, 2009
    yes i can see the circles but now how do i test it?
    YES I CAN SEE THE CIRCILS NOW HOW DO I TEST THE PARTS?
    SO CAN I JUST TAKE A TESTER AND TEST THE IN AND OUT ON THAT B+?
    OK I WILL TRY IT BUT IM NOT HOME NOW SO I WILL WHEN I GET HOME AND LET YA KNOW.
    ok so i tryed it and on the primary one i got a reading from 11.01 to 12.58 and in the secondary one i got a reading from 12.25 to 12.60. so is that a good thing? what can i try next?
    hi okay i tryed it and this is what i got the first pic is the power out of the B+ and the second pic is what im getting on all the little diodes around the B+
    the voltage for the black tubes is rated for 200 volts a peice and the part number for the B+ is SE1352521N. and im getting 6.8 dv on the B+
    okay is it a bad thing that the B+ broke off?
SOURCE: APEX TV problems
need flyback transformer #030531-5283
Posted on Sep 24, 2007
  • 18 Answers
SOURCE: Apex GB51HD09 will not turn on
On the power board you will find 4- 35Volt X 1000mfd radial lead capacitors on the right rear corner of the board all in a row from right to left, the 2 outside capacitors have gone high ESR. This is a common problem with this model.
Posted on Dec 27, 2007
SOURCE: tv power light blinks but it won't turn on apex gb43hd10
htyjkyukiuy;l.ioph';po';pio;'
Posted on Apr 13, 2008
  • 7 Answers
SOURCE: Problems with my Apex CHKT2A remote
I've seen remote sensors that quit but it's rare, usually due to water getting dripped on them from cleaning. Pick up a cheap programmable remote and see if it will work. Long shot, check the menu, in some sets the remote can be programmed off.
Posted on Apr 15, 2008
SOURCE: TV won't come on
unplug it for 10 minutes then turn it on at the console(not the remore) and hold the power button in for 15 seconds. this resets most apex tv's
Posted on Apr 05, 2009
TV turns on then cutts off
that buzzing is the high end power trying to turn the lamp on.... the electrical current and shock is what turn your lamp on your tv which is what the buzzing is dont worry thats normal...however your solution is buy a new lamp for your tv but make sure its the right serial number for lamp u cant just buy any lamp. best place to buy one ebay.... as in the lamp still trying to light up its only because the electrical current going into the lamp and then cutting off causing the red light on your tv....so other words all it is is the lamp... CAUTION!!!! those lamps get up to 400 degrees unplug tv to ensure no electrical current.... hope i helped.... JACOB WINKLER
Jul 16, 2012 | Toshiba 46HM95 46" HDTV
My SOny Projection HDTV makes buzzing noise when turned on
if tv is a dlp you have eithor a bad color wheel or bad fan.would need model number to research it more
Sep 07, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Apex gb55hd09w
you need two STK392-020 - 3-Channel Convergence Correction Circuits. they run anywhere from $10 to 40, then either you or electronics shop solder them in
Oct 18, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
TV won't come on
Oct 06, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
My flat screen tv is making a buzzing noise
my flat tv is hot when used after 30 min. or so
Sep 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Service manual to fix color convergence
I would like a service manual for this tv as well if anybody has one. However i did call apex and they said there is no service manual for this tv
Jul 01, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Convergence issue
Replace both convergence ICs number STK392-020 you can get replacements at the following link and they provide free instructions woth pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/
May 14, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
Sep 12, 2006 | RCA F25649 25" TV
Apex Digital GB55HD09W 55" Rear Projection Television Logo
404 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
