Copiers
Problem for Copiers
Generic problem for all Copiers
Minolta EO 1080 Copier-Error Code C05
By doggonnet on Oct 13, 2007
I have an ancient Minolat 1080 ep.  I have replaced EVERYTHING.  Now I get an error code C05.  I don't have a manual for this POS.  What clears it?
Same Problem
Jun 10, 2008
-   Can't find the trouble reset button!! Help!!-   Guest
Best Solution
posted on Oct 15, 2007
Helpful)
The Otrain
Rank: Guide
Rating: 90%, 14 votes
Did you do anything to the fusing unit (ie cleaning thermistors or replacing the fuser roller?) That code means you have a temperature problem.  It will also come up if your power cord is loose.  You can check it by taking off the back cover of the copier and pressing in the trouble reset button while the copier is on.  It's a small black button. If the code goes away, you're good to go. If it comes back, you might have to replace some of your fuser components.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Oct 30, 2009
Not Rated)
pariseridesi
Rank: Apprentice
Rating: 0%, 0 votes
I have a Cannon 1080PC that has a paper Jam and can not get to it. Any suggestions
Was this helpful?
Yes
No
Solution #3
posted on Feb 18, 2009
Not Rated)
edithc199
Rank: Apprentice
Rating: 0%, 0 votes
how do you replace the drum for minolta ep 1080
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
konikaminolta1216
Answer
i have a used canon c130f and am in need of basic info to get it plugged in i.e. rj45 connection.... (More)
Answer
my sharp photo copier is showing H5 problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
