Question about Toshiba Office Equipment & Supplies
Upper tray will not lift if castomer oper tray but he will go up if customer turn machine off and on
    Sergeant:
  • 199 Answers
There are sensor problem
Posted on May 12, 2009
HP 4350 with a 41.3 error- Paper size is set correctly and size switch actuator is OK. I tried another tray and also tray 1 (manual feed tray). That tray jams- no lift to feed roller. Any ideas?
I have seen many diferent 41.3 errors. Start by making sure tray is set to standard instead of custom and reset machine to factory settings. Next change out the roller assembly behind the tray 1. It has the selonoid on it. I have seen that cause it before. I would just replace the entire tray 1 to solve the no lift. good luck
Apr 08, 2013 | HP LaserJet 4350 Printer
Toshiba estudio 282 has error code cc90--how to reboot copier?
good day cc90 is the top tray of your finisher (sorter) is causing the fault it is usually caused by there was something heavy put on the top tray or somebody bumped the tray. the bushes on the tray that is lifted by the motor are faulty and need to be replaced by a qualified technician if you need to use the machine please switch off the machine and unplug the finisher (sorter) switch on and the machine will work and obviously not sort or staple i hope that this quick fix will help you out until a technician can repar your finisher (the plug for the finisher is at the back of the machine above the power inlet behind a small cover)
Apr 06, 2011 | Toshiba e-STUDIO 282 Black and White...
I have a canon copier with colater the colater when you start the machine goes down and just clicks and never comes back up again. The screen gives me error code E000540-0001
E540
Main Cause: The tray home position sensor (PI8) is faulty. The tray lifter motor clock
sensor 1/2 (PI9/PI19) is faulty. The tray upper limit detecting switch (MS5)
is faulty. The tray lifter motor (M5) is faulty. The finisher controller PCB is
faulty.
0001 The ascent does not end in 15 secs when the tray lift motor is
driven; or, the tray home position cannot be detected when the tray
lift motor has been driven for 15 secs.
Feb 10, 2011 | Canon imageRUNNER 6020 Copier
We have a Konica Minolta Di2010 - we are getting a message on the screen that read: "A malfunction was detected. Please call your tech rep with this code: C0920" What can I do to get the...
C0920 as per the Minolta Factory Service manual is caused by a tray 1 lift motor failure. In my experience with this code, it is usually caused by paper loading in the tray or something jamming the tray. Best solution is to remove all paper from the tray. Leave the tray open an inch or 2 and turn the main power switch off then back on. The main power is on the back of the machine NOT the one on the right edge of the operation panel. Once the code has been cleared then try a test copy by using one of the remaining trays. If it works correctly then re supply paper into the top tray 1 and then see if the code returns. If it does then either your lift motor is bad or you have something jamming up the lift plate in the paper tray. You can always leave that tray open and run the machine until you can get someone out to look at it. Most of the time tho, reloading the paper in the tray will solve the code.
Good Luck and Thank You for using Fixya
WheatlandServices
Dec 16, 2010 | Konica Minolta Office Equipment & Supplies
A paper jam was not cleared in a timely manner, now the machine will only display "Error Code C0202, Call Technician" It is Saturday and I can not get a hold of anyone at our support center. How can I...
C0202= tray 1 elevator failure.
Open tray 1, check and make sure paper is loaded correctly.
With tray open, open and close front door. This will reset error code. With tray 1 open look to see if paper is stuck behind tray in back of machine, if so remove it ( this will block the lift motor for the tray).
Close tray 1, if you hear a popping noise the lift motor is damaged and will have to be replaced. Until it is replaced operate machine with tray 1 out to prevent error code.
Sep 18, 2010 | Konica Minolta Bizhub 362 Copier
F3 ERROR CODES
This code indicates a fault with the paper tray lift-up motor. F3-12 = tray 1, F3-22 = tray 2 etc. To clear this fault switch off at the power supply and empty the indicated tray of all apaper and jams. Operate the lift up section and then close the drawer with NO paper in drawe. Switch on again and after the machine boots up replace the paper in the drawer. This usually works fine unless there is a serious problem with the lift-up motor.
Feb 19, 2010 | Sharp AR-5320 Black and White Copier
Xerox Phaser 8550 error message 11.001.47
The Upper 535 sheet feeder is not being detected.
Lots of things can cause that. Loose grounds.
A bad connection to the power board, A pinched harness, A bad Input output board,Electronics module,
Going to be a difficult one to track down.
One thing to take note of, that could be easy. There is a posibillity that the tray lift motor is not working. Shove the paper tray in and listen for the tray to lift. Pull the tray out and see if it is dropping.
If not, you could be fortunate enough to have a bad tray lift motor.
YOu may want to open the back cover plate, WITH THE MACHINE OFF and remove the memory and try resetting that.
the .47 indicates a tray lift problem.
Looking at the documentation it states that either the lift motor has failed, and if that does not resolve the problem the Electronics module has failed. The Electronics module is very expensive.
Jan 20, 2010 | Xerox Phaser 8500/DN Printer
Sharp AR-M550 with a paper tray error F3-12
When I first arrive to any service call the first thing I look for is the service log.
Locate the service log on the rear,side or inside the front cover.
Check the last error code and corrective action.
F3-12, Paper does not lift in the tray
Identify how many lift tray is inside your machine.
Check each sensor(s) for smooth operation.
LOOK inside for crack plastic on the lift tray.
Sensor can be defective (non-operational) and no cutting off power to the motor and damage the motor,metal frame and plastic tray.
Use a small METRO VACUUM with a clean bag,
Vac the interior of the unit,
Look for fragment of plastic tray or sensor arm inside the vacuum bag.
Pass the information to a Sharp authorize shop.
Dec 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
HP Color LaserJet 8550DN input device failure, check cables and cycle power | error code: 66.01.02
This error message indicates a lifter malfunction has occurred. When the 2000-sheet input tray (Tray 4) is closed, the paper deck lifts the paper stack until it is just below the feed rollers. Photosensor flag PS34, the paper surface photosensor, determines when the paper stack is lifted into the feed position. When PS34 does not detect paper in the expected time, the printer reports a 66 error. SOLUTION: Follow the steps below to troubleshoot and resolve the issue.
  1. Turn the printer off, open and close the tray, then turn the printer back on to see if the error clears.
  2. Open the drawer and check for extra paper or items stored on the left side of the tray. This will prevent the tray from lifting due to excess weight or blocking the lift of the tray.
  3. Remove all the paper from the tray. Remove the tray guides and reseat them. Verify the guides are not bent or broken.
  4. Lift the paper deck manually to verify there are no obstructions in the path.
  5. Pull the tray out as far as possible and observe the white bushing on the back right side of the tray. If the white bushing is broken, the tray will not lift properly.
Oct 23, 2009 | HP Digital Sender 9100C Multifunction...
Aficio 1035 ps
Finisher 1 tray lift motor error.
It should be looked at by a technician to see if the sensor or motor needs to be replaced.
If you want to use the machine for now and bypass the error. Turn the power off on the copier. locate the finisher cable in the back of the machine. Pinch and release the cable and turn the power back on.
Jul 11, 2008 | Ricoh Aficio 1035 Copier
32 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
