Question about Kenmore Dryers
Dryer will not heat up and heating element is fine ?
    Brigadier General:
  • 8,619 Answers
Hi
Power from the house-- Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element-- Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse -- On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring -- A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Posted on May 12, 2009
Dryer not heating
Did you check to see if the new heating element is receiving power? If no power, did you check the switch that feeds the element?
Oct 20, 2015 | Dryers
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
Dryer will spin but not dry , heat element is fine
Try replacing the high limit switches if the element is fine. The limit switches will not allow power to the heat strips if they are blown. They are the little silver buttons on the heat strip. There are usually two wires connected to them one coming from the controls and one from the heat strip itself
Dave
Mar 05, 2010 | Magic Chef CYE4000AWW Electric Dryer
Dryer willnot heat
heating eliment is most likely burned out. Better off getting new dryer. But if that is not an option then call a repair person that can replace the heating element.
Nov 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Top works fine, bottom no heat, does this unit have seperate heating elements or could it just be the internal fuse
Are you talking about the element you where looking into the element shroud and that is what you saw? If so your element is gone you can buy a complete element at your local parts depot.The element is fused on to the shroud makeing a dead short. Hope i fixya :)
May 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Apr 13, 2009 | Kenmore 62802 Electric Dryer
Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Dec 24, 2008 | Amana Dryers
No heat
Check the resistance of the heating element (8 to 14 ohms). If ok, then check continuity of the overload devices attached to the heat element duct. If either one or both are open then replace ($14 for both). Dryer should heat.
If heat element is faulty, the part can be purchased at Sears/Kenmore Parts Center and swapped out ($45.00).
Provide your dryer model number and ask for the needed parts.
Unplug your dryer first before attempting any service work. Safety first and always!
Dec 19, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
56 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
