Question about Garden
Tooo much fuel pull cord fuel expels through exhast.
Found vacuum hose off mower after i found out was flooding.cleaned up fixed hose now pull cord lots of gas pours out. murray 3.5 20` mower thankyou
  • 246 Answers
Hello aurora12104:
The Carburetor Float Needle Valve is Not Seating Properly and is Causing the Engine to Flood or the Head Gasket is Blown between the Push Tube Galley and Cylinder and the Head Gasket Requires Replacing.
Check the Oil and Make Sure it has Not become Contaminated with Gas. Change Oil if it has a Gas Smell or the Crankcase is Over Filled.
Soak and Clean the Carburetor and Replace the Float Needle Valve.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
    President:
  • 1,545 Answers
Jbridger You give this same advice to everyone whom you conclude has a carb problem. The problem with that is that in the case of the ZAMA carb...there are sensitive check-valves in the primer base, in the main nozzle, and in the low-speed idle circuit. ZAMA states in their tech guide for their carbs DO NOT SOAK for this reason. Gunk cleaner is a very strong solvent and the sensitive parts can be damaged if exposed to those chemicals too long. For those working on ZAMA carbs, visit: http://zamacarb.com/pdfs/TechGuide_2007.pdf
Posted on Oct 15, 2009
1997 sl2 satun started with rough idol now won't start . cranks over and floods. has new fuel filter & air filter
Check the fuel pressure regulator. Pull the vacuum hose off it, If it smells of gas, Replace the regulator. Diaphragm broke and is flooding the engine threw that vacuum line. You'll also need to replace the spark plugs. Gas will foul them out also.
Dec 31, 2016 | Cars & Trucks
Mower will only run on choke.pulled carb apart 4 times.still the same.bought brand new carb.still the same.any ideas
Like you I would have immediately thought lack of fuel, not knowing which make and model I will throw a few thoughts out there. On some mowers when the gas tank is under the seat it is lower then the carburetor so it has a fuel pump that lifts the fuel into the carburetor. If you follow the fuel line from the carb like you are going to the gas tank you would find it sometimes on the engine because it can be mechanically driven off the cam shaft, might be bolted to the engine because it is vacuum driven and with that in mind pulling the choke would increase the vacuum to over come a vacuum leak and it could be electric fuel pump and comes on with the key. If your tank is under the seat or lower then your carb Start with pulling off the hose from the carb putting it in a jar or can and crank the engine like you are trying to start, there should be gas coming out, At this point I need to know what you have found at this point. How to find fix and install lawn mower fuel pump
Apr 02, 2016 | Garden
How do i fix flooding problem on 95 camaro?
What engine does it have ? 3.8L ? Could have a bad fuel pressure regulator , leaking fuel injectors . How many miles on it ? Pull the vacuum hose off the fuel pressure regulator an see if it is wet with fuel .
Mar 06, 2015 | Chevrolet Cars & Trucks
How to repair gas in oil problem for 21 HP brigg and straton engine
Most times a good cleaning and rebuild of the carburetor will fix this problem. Most it is the needle valve and seat that leaks.
One extra thing to check if this engine has vacuum operated fuel pump is see if fuel pump diaphragm has ruptured or not. If it has ruptured fuel can get into the crankcase via the vacuum hose.
Oct 10, 2014 | Garden
I accidentally put diesel into the car, about 10 litres. What do I need to do to rectify this?
Hi, you will need to pump it out. It is best if you can pump it from the fuel rail, so that only a minimal amount would get into the injectors. You can do this by removing the fuel return hose from the fuel pressure regulator and attaching a hose that you will lead to a bucket. With the hose in the bucket, turn the key on so the fuel pump runs. If the fuel pump will not stay on, please get back to me, and I will provide a relay bypass procedure toi keep the pump running. With the pump running, the diesel should come out the return port into the bucket. If it comes out too slowly, try pulling a vacuum on the vacuum hose that's attached to the regulator. You can use your mouth to pull the vacuum if you attach a clean hose. Once you have all of the diesel out, put in some petrol and pump a couple liters of that through as well. Then reconnect the hoses, and the car should start OK. Please let me know if you have questions.
Apr 21, 2011 | 1996 Honda Odyssey
Poulan Wildthing pull starter problem hard pull; have changed fuel filter; pull starter works with spark plug out, but still hard on the odd pull with starter in?
Many modern saws have sufficient compression to present difficult pulling of the starter cord. Suggest trading in for a saw with a compression release. The only repairable problem with the present saw is if it is flooding the engine and you are trying to compress liquid fuel. You can tell by removing the spark plug and pulling the starter through forcefully--it will blow out raw fuel if it is flooded. Change the diaphragm in the lower carburetor chamber if it is flooded. Hope some of this helps!
Jun 22, 2010 | Garden
When yanking on the pull cord to start engine
Im guessing that you have started it before, so I guess , check that its not flooding ,pull air filter out see If you can see heaps of fuel in the bottom hole ,if you do take spark plug out pull cord a few times without holding start cable or you will catch on fire replace spark plug try starting ,no start still flooding take it to a lawn mower place ,float may have a hole in it , if not flooding, on the bottom of the cardy one brass nut , four holes find them clear then, start also a brass pipe going into the center of the carby is probable blocked
Jun 18, 2010 | Mtd 22" Yard Machine Push Mower
My 2 stroke whipper snipper won't start
As with all 2 stroke engines,
1. Pump the fuel plug. 3 -5 times.
2. Turn the stop botton onto start.
3. Choke onto hot.
4. Pull the cord . Most important... dont touch the throttle trigger when pulling the cord. Wait until until it starts up.
If you do. (like it says in the instructions, your flooding the engine)
Works every time for me on everyone's whipper snippers.
Feb 09, 2010 | Ryobi Garden
Mastercarft gas lawn mower
Take the unit outdoors. BE SAFE!
Remove the spark plug and pull the rope SLOWLY to expell any excess fuel from a possible flooded condition.
If no fuel, leave the spark plug out and check for bent blade and/or crankshaft. If bent, it is likely the flywheel key is sheared and ignition timing has been affected. If you feel the need for a manual to perform this task then perhaps this is a job for a qualified repair shop.
No offense intended what-so-ever!
If crankshaft is bent, ALL engine manufacturers recommend replacement by an Authorized Service Center.
Hope this helps.
Sep 29, 2009 | Garden
The engine on my Sprint 375 floods when trying to start
Check the float in the carb. bowl for gumming and clean your carb.. If you haven't done so already. Or you can try running a fuel treatment through your fuel. That may help you with your flooding issues. Good luck.
May 04, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
383 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
