Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
My ryobi 31cc 15" 700r won't start
I started it once and was able to use it. i 'tried starting it again and it wouldn't start. i noticed it was low on fuel so i added the unleaded gas and ryobi mixture and it still wouldn't start. what can i do to solve this problem
    President:
  • 272 Answers
You need to push the primer button 10 times or so (the button at the top of the speed control) to get the gass pumped up into the system again. Likely gas not getting through the line yet. Takes awhile.
Posted on May 12, 2009
I have a Ryobi 410r 31cc tiller. It will start and run for acouple of minutes then stop.
take off the muffler and try it again if better then open the muffler and clean the screen most pry open
Aug 18, 2012 | Ryobi Garden
It has very low compression and the start assist dont seem to be kicking in
Low compression could be due to carboned-up ring that is sticking. You could remove the exhaust muffler and look inside the port and check the condition of said ring by adjusting piston position. You probably wouldn't notice the start assist working if the compression is low, because the start assist MAKES it feel that way under normal starting conditions. Poke into exhaust port after removing the muffler with a sharp tool and see if the ring is free. It is not supposed to move much, just wiggle a little. If it is stuck, you should be able to tell and disassembly and cleaning will be required.
Sep 06, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Aug 01, 2009 | Ryobi Garden
Ryobi 31cc , 17inch weed ,hard to start ,needs to stay choked to
I got on here to find the solution for the same problem. This seems to be fairly common. I need to have it at 3/4 choke to run properly. Other posts say the exact same thing, about the 3/4 choke. It is apparenly something that breaks occationally.
I'm going to remove the carb and take it apart. My suspection is the diaphram in the bottom of the carb. There isn't much you can do with the carb, it is very simple and has few parts.
There is a chance that it is a blocked passageway also.
There are instructions for adjusting the mixture, but they are not clear enough. I will be posting a clarification reqest on one of those posts. Will also post again after I check the diaphram.
Jul 11, 2009 | Ryobi Three Trimmer Combo
Ryobi 31cc lawn trimmer carb adjustment
As with all 2 strokes if you have compression and a reasonable spark, you only need fresh fuel with correct oil ratio) and they must go !(as long as you haven't fiddled first and all gaskets are sealing) I start mine by(1) pumping the primer till it is firm,(2) full choke,(3) pull till it kicks ONCE,(4) half choke, pull till it runs,allow to warm up and(5) switch to run (you may need to apply a bit of throttle while pulling as in (4)(or give it a few more pumps if it dies) If all is ok, check that when properly warmed up there is a smooth transition from idle to full revs, if it hesitates it may need the LOW SPEED mixture leaning (clockwise) SLIGHTLY.If it dies the LOW SPEED mixture may need richening(anti-clockwise)(adjust 1/8 turn at a time) Make sure that motor is just peaking at full revs and is on the RICH side of peaking (HIGH SPEED mixture)(this will avoid seizing it Adjust both till it revs cleanly and is JUST rich at full, and idleing nicely and it should start without too much trouble.(If you have fiddled and are lost,-about 2 1/2 turns out from closed on both needles should get you started)
Nov 23, 2008 | Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
780 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
