Question about General Filters 1042-LH Humidifier
General 1042 What is the difference between General 1042 and general 1042-LH?
The 1042 has a valve that operates on 120 VAC. The 1042-LH has a valve that operates on 24V.
Posted on Dec 16, 2007
Frequent knocking noise coming from General Aire 1042 LH humidifier
Hello, it depends where the sound is coming from,if it's in the supply water line it could be caused by water hamer or the inlet side of the solenoid valve might be clogged up with sediment. Water hammer is when the solenoid closes under high water pressure and a water hammer arresters should be installed. If the sound is coming directly from the solenoid valve and is more of a chattering sound then there is a loose low voltage wire or the solenoid is going bad. If you disconnect the power to the solenoid and the chattering stops then solenoid must be replaced as it is the cause of the noise.
Mar 17, 2011 | General Filters 1042-LH Humidifier
I have a General Filters 1042-LH Humidifier in my home what setting should it be he choice low/ med /high live in Michigan
Sorry to read about your problem, I hope this helps you out.
OUTSIDE TEMPERATURE RECOMMENDED SETTING
-20F -29C 15%
-10F -23C 20%
0F -18C 25%
+10F -29C 30%
+20F - 7C 35%
+30F - 1C 40%
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | General Filters 1042-LH Humidifier
My 1042 L General humidifier is not putting moisture in the air eventhough water is getting to the filter
General 1042-L not putting moisture in the air. Water valve is open and getting to the filter. The unit is clean.
Dec 01, 2009 | General Filters 1042-LH Humidifier
How to fix 1042 Error
format your whole pc there may be some virus.......then install it
Jun 14, 2009 | General Filters 1042-LH Humidifier
What's the best way to clean a 1042 filter
best solution I have found to clean them is to buy yourself some (CLR) seems to work the best, I would recommend soaking as much of it as possible, the longer you let it work the better the results, hope that helped
Jan 19, 2009 | General Filters 1042-LH Humidifier
Water leaking out of bottom
A leaking humidifier is a sign that the unit's filter needs to be cleaned/changed. I had the exact same problem on this model.
Jan 05, 2009 | General Filters 1042-LH Humidifier
Change filter
http://www.ontimemall.com/How_to_change_990-13_Pad.pdf
Nov 16, 2008 | General Filters 1042-LH Humidifier
General Filters 1042-LH Humidifier Logo
481 people viewed this question
Top General Filters Humidifiers Experts
Paul Carew
jdthefixer
Steve
Are you a General Filters Humidifier Expert? Answer questions, earn points and help others
