Question about AdobeAir Evaporative Cooler Direct Drive
Air coming out of an adobeair portable evap cooler isnt cold
I just bought this used adobeair portable evap cooler however the air isnt coming out very cold... why?
    Problem Solver:
  • 11 Answers
Paula298,
A new unit will take a while for the pad to become wet and more efficient. Remember, there may be two switches: fan and water pump. The unit must be full of water and the pump ON to work correctly.
If the unit has a water pump only setting, run the pump without the fan for about 20 minutes. That will get the pads nice and wet and you should get a good result. A rule of thumb in the desert is 20 to 25 degrees of cooling compared to the ambient air.
Don't use a cooler in closed area. The cooler will simply act like a room humidifier. Use in an open garage or porch for the best result.
I hope that helps.
Ed Phillips ed@azalmanac.com
Posted on May 31, 2009
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
How to remove a motor from a plastic fan wheel on a portable evaporative cooler
There should e a set screw on it that you can loosen. Then the wheel can be removed.
May 31, 2014 | AdobeAir Mobile Swamp Evaporative Air...
The unit in question is a Master Cool portable evap cooler model #P500A. Everything operates perfectly accept the fan blower unit when turn on. Switch panel lights up but no blower operation. Are their...
The bearing on the blower motor are probably rusted or stuck from winter storage but you can disassemble the cooler and try to re-grease the blower motor front main bearing to access the rear bearing you have to take apart the blower motor . i had the same problem with my two p500a models and they work perfect now . i couldn't find any replacement parts but if i do i'll post the web site here hope this helps you with your problem N0D0ZE
Jul 22, 2011 | AdobeAir Adobe Air 550 CFM Portable...
How to clean water tank
Go to Lowes-Home Depot-Ace Hardware. In the evap cooler section they'll have a bottle of scale remover for sale. Just follow the directions on the bottle.
Aug 11, 2010 | AdobeAir WisperCool MMB8 Portable Air...
Does it need to be cleaned, if so. how is that done? AdobeAir /Mastercool model P700 serial number B150809633
Yes, it needs to be cleaned. Go to your local home store and (in the evap cooler section) pick up a bottle of evap cleaner/scale remover. Just follow the directions on the bottle. It will last MUCH longer with proper care and cleaning.
Jul 06, 2010 | Mastercool Portable Air Conditioner
Cooler Pads
Try here: http://www.eautotools.com/Adobe-Air-ADOPK100-p/adopk100.htm
I've had good luck going to an AC supply house and just asking what kind of cheap pads they had in stock, then cutting them to fit my units.
Apr 19, 2010 | AdobeAir WisperCool MMB8 Portable Air...
I have 550 CFM cooler and the air is blowing but
you need to open up and clean the pump unless gravity fed but still need to cleaned. or new pump.
Jul 11, 2009 | AdobeAir Adobe Air 550 CFM Portable...
How to turn it on? wisper cool
Try this : http://www.impco.com.mx/manuales/artic/Manual%20MMB8.pdf
Jul 08, 2009 | AdobeAir WisperCool MMB8 Portable Air...
Remove the front and rear panels off of a MasterCool P12
Lift yhe panel and pull out at bottom. The ones that come out usually have hand slots
Jun 09, 2009 | AdobeAir Mobile Swamp Evaporative Air...
AdobeAir Evaporative Cooler Direct Drive Logo
248 people viewed this question
Top AdobeAir Welding Tools Experts
Bill Boyd
Are you an AdobeAir Welding Tool Expert? Answer questions, earn points and help others
