Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
I started it once and i can't get it to start again
The fuel was low so i added the ryobi oil and unleaded gas mixture but it still won't start
  • Jerry Cramer May 11, 2010
    Tell me some history has it been sitting with gas in it for a time ?
2 Suggested Answers
  • 272 Answers
SOURCE: my ryobi 31cc 15" 700r won't start
You need to push the primer button 10 times or so (the button at the top of the speed control) to get the gass pumped up into the system again. Likely gas not getting through the line yet. Takes awhile.
Posted on May 12, 2009
Ryobi ry08576
make sure your fuel is fresh and mix at 50:1
then remove the muffler and try to start it holding the throttle wide open... if it starts and runs fair suspect a flooded engine, plugged muffler
if not, suspect a carb adjustment issue and then a carb
Aug 14, 2014 | Ryobi Backpack Blower 25.4cc
Should I use unleaded regular or Ethanol free gas for ryobi weed eater
Always use ethanol fuel in everything you can. If you can't find ethanol fuel then buy StarTron fuel additive and use that to help with the ethanol issues
Jan 24, 2013 | Garden
I want to confirm the ratio of fuel (unleaded petrol) to oil mixture for my Ryobi chain saw, model CS3816. Is it 50:1? What oil do I use?
Hi afs3...
Yes use the 50:1 oil to gas ration. 1 pint of 2 cycle oil to 6 gallons of gasoline.
Please take time to rate me
Sep 04, 2011 | Garden
Could you please let me know. 1] Can I use E10 fuel in my new RLT 30 CET 30cc trimmer that I have just purchased and am yet to start up? 2] Is 50 to 1 50mm of oil to one litre of petrol?
Hi and welcome to FixYa, I am Kelly
First off the engine is designed to operate on unleaded fuel. The manufacturer makes no statements at all about E-10 Fuel. I will tell you from experience that you can use E-10 Fuel but.... should you ever have a warranty claim make sure the entire fuel system is 100% unleaded pre-mixed fuel. Your not going to hurt the unit using E-10 fuel as long as you maintain the proper fuel-oil mixtures. If anything a splash more of 2 stroke oil as in 22 mm / liter vs 20 mm. Or (+) 8 mm per gal.
Manufacturers statemenrts and recommended fuel mixtures below:
Thanks for choosing FixYa,
Kelly
n This product is powered by a 2-stroke engine and
requires pre-mixed petrol and 2-stroke lubricant . Premix
unleaded petrol and 2-stroke engine lubricant in
a clean container approved for petrol.
n This engine is certified to operate on unleaded petrol
intended for automotive use with an octane rating
of 87 ([R + M] / 2) or higher.
1 Litre + 2 0 ml =
2 Litres + 4 0 ml =
3 Litres + 60 ml = 50:1 (2%)
4 Litres + 80 ml =
5 Litres + 100 ml =
The full operators manual is here:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Feb 27, 2011 | Ryobi 15" Electric Factory Reconditioned...
Gas to oil mixture for Model # RY 28020
Use 2-Cycle Oil For Mixture of 50:1. They come in 2.6 oz bottles and larger. Use 2.6oz (one small bottle) per 1 gallon of 89 unleaded gasoline. I use and this and it runs like a charm. You can get from HomeDepot or other hardware stores.
Jun 18, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
As dum as they come
dsc-w110 sony cyber shot flash on or auto mode capture picture idark but flash off condition picture is ok
Mar 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Husband put unleaded gas with the oil added due to a 2 cycle engine, now it won't run
not clear on the problem?
I think you mean he has to add 2 stroke oil to the gas then fill up the blower then start it but it won't start? If the mixture is wrong it wont run well if at all.
Check the spark plug has a spark (unscrew it rest it against metal body with HT lead attached and try to start it, keep clear of the lead tho don't hold it in place!! it can be shocking. Check the unit isn't flooded (very wet spark plug).
try starting it with no choke, try several times then gradually increase choke, is it try to run yet?
Jan 15, 2010 | Poulan Featherlite Gas Blower, with Low...
Problem with Ryobi Restarting
you need to replace the fuel filter in the tank ,must be fished out of tank with a coat hanger to the filler hole to be replaced
Sep 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My ryobi 31cc 15" 700r won't start
May 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
170 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
