Our Kenmore Advantage washer stopped midwash and my wife said she thought it sounded like a belt breaking but I've looked in the parts book and don't see any belts, anyway, agitator won't move. Thanks for any info
  • 351 Answers
Have a look under the machine, should be a pulley on the elec motor and another on the centre shaft of the tub which goes through to the bottom pulley
Not sure if you have a top loader or a front loader
If that machine is a late model it may not be as I described but it won't hurt to have a look anyway
Posted on May 12, 2009
My washer stopped while doing a load of laundry, the water wouldn't drain so I scooped that out and when I looked under the washer I found something that looked like a small belt that had snapped. My...
kenmore washer series 80 runs for 30 seconds cuts off for a while and runs 30 seconds and cuts off again, makes it through cycle in about four hours????????
May 31, 2011 | Washing Machines
Kenmore washer model 110 26712690 fills up with water and does nothing. wife said she smelt something burning. I thought maybe a belt but when I took it apart I didnt see any belts.
no belts in a kenmore,if it filled with water and stopped most likely you have a bad lid switch.close the lid,open it up a few inches and close it down a few times,if you don't hear a clicking sound every time you open and close it the lid switch is bad.,if you already have it apart,you can jump it out,the white harness you disconnected next to the right clip is the lid switch harness,stick a wire in the two outside holes,put it on spin and pull the timer out,it will run.the model number you sent isn't correct,i was gonna give you the part number and price of the switch,just give it to your parts store and they will sell you the correct part.
May 15, 2011 | Kenmore 22422 Top Load Washer
Last night my wife was using the washer and when the washer went into the spin cycle it sounded like the washer was chugging. The drum was turning but not at full capability. the washer is a Kenmore...
I had a Kenmore washer that had a somewhat similar problem. It had a rubber sprocket that had started to deteriorate that caused my drum to stop spinning. I'm not sure if your is the same but you might try pulling the back panel and see how the drum is driven. I am guessing the sprocket or belt has started to wear out.
Jan 27, 2011 | Kenmore Washing Machines
My dryer won't turn on (start button?) The timer works though. It quit working in the middle of a cycle and I'm pretty sure the heat was still working, it just stopped working.
Sound`s like a broken drum belt. When the belt break`s on most kenmore/whirlpool dryer`s it prevent`s the unit from starting via a ``kill switch`` located under or next to the belt tensioner/idler pulley.
Since you`ve indicated the timer appear`s to advance/work, it is not the thermal fuse/cut-out.
The other possible fault is in the start button, but that is not very common.
I`d look at the belt. That`s what I`d check first. Hope that help`s.
Good luck and thank`s for visiting fixya.
macmarkus :)
Dec 13, 2009 | Kenmore Dryers
WASHER WILL NOT RINSE OR SPIN
First, call 911 (just kidding).
Sounds like the belt is loose or broken. Remove back and have a look see. Unplug first!!!
May 05, 2009 | Kenmore 24902 Top Load Washer
The washer driving belt breaks.
Sounds like a spin bearing might be bad:
Check this link:
http://www.fixya.com/support/t197849-burning_smell_screeching_sound_but
Apr 21, 2009 | Kenmore Washing Machines
What is belt-like part doing on a kenmore direct drive washer!?
its a sound deadener. the washer will work fine with out it
Feb 07, 2009 | Kenmore 24032\24036 Top Load Washer
WHIRLPOOL ELECTRIC WASHER STOPPED WORKING MIDWASH BC OF OVERLOAD?
My wife did the same thing,trying to do all the laundry at one time.Even if it says high load compasity it will only handle so much.sounds like you killed your motor.Hope this helped.
For more help go to live chat.
lenwest
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
