Question about Motorola Mobility RAZR V3i Cellular Phone
Speaker problem My fone was working perfectly all right but now its speaker doesnt work. I have to turn on loudspeaker to reveive or send a call. I never mishandled my fone like dropping or wetting. I did master reset but still the problem remains. Formatting the fone may be one solution but I dont know how to format it. Kindly suggest me solution to this problem.
  • 490 Answers
See budy in ur handset the last option is to master reste the handset, if u have allready done that fine, than u have to consult with ur vendor most probably there could be something wrong with the speaker, there might not be any software issue with this. but for ur meaning own heart u can format  it also.
Posted on Oct 19, 2007
SOURCE:
My hp laptop dm4 when i connect earphone it works perfectly but it doesnt sound on the speakers
Check the audio controls. Check the loudspeaker icon is not muted. Check the socket is not damaged.
Jul 18, 2014 | HEWLETT-PACKARD HP Pavilion dm4-1165dx...
Onkyo HT R520 Home Theatre reveiver/amplifier problem
If you have isolated the problem to the receiver/amplifier, it will be necessary to find out why that output is dead
Oct 04, 2012 | Onkyo Audio Players & Recorders
My amp isn't producing any sound. It works when headphones are in but that's it. Please help
The headphones socket is on the preamp stage - it works so the problem must be after the pre-amp.
Do you get any sound at all from the speakers (hiss or perhaps a click) when you turn it on?
If yes it is an amplifier problem.
Here are some possible causes
  • A wire has come off the loudspeaker - easy to fix
  • Speaker protection fuse has blown - small glass fuse mounted on main amplifier chassis - replace with correct rated and type of fuse (note some of these are 'slow' blow type - important that you get the right one)
  • faulty component in the main amplifier stage - requires attention from qualified repairer
  • Loudspeaker burnt out - this can be tested by connecting another speaker across the terminals of the built in speaker.
  • The headphone jack socket automatically disconnects the loudspeaker when phones are plugged in - it could be that the contact in the headphone jack socket is bent and not re-making contact when the headphones are unplugged.
Feb 26, 2011 | Orange Crush 15r 15w Reverb Guitar...
My phone nokia 5130, it doesn't work at this time. But on the following days i can use with loudspeaker only now it doesn;t work
hi :) u mean before u can use with loudspeaker,mean the speaker hearing people talking cant work ?? if now both speaker cant work,mean both speaker was apoil.pls send to mobile shop exchange new speaker.
Jul 06, 2010 | Nokia 5130 Cellular Phone
How to switch on loudspeaker in nokia 3110?
Dear sir,
when the call is in duration there is the option of Loudspeaker in the extreme left/right of the cell fone. :)
From there you can switch on loudspeakers. :)
Take care.
Dec 14, 2009 | Cell Phones
Loud Speaker not activating
You open the mobile and check speaker by multimeter.
if it is damage than replace it.
or if it is right then solder on the speaker tips,
Aug 14, 2009 | Nokia N78 Smartphone
Right loudspeaker problem
Doesnt sound like the selector as it "sometimes" works. Redo the speaker connections on the back of the amp and speakers first. If it persists, swop the speakers and cables, if the problem swops, then it could be inside the speaker or the cable, if still the same then amp has dry joints/loose connections probably
Jun 24, 2009 | NAD C372 Amplifier
Sony Ericsson W850i Aerial and Loudspeaker Problems
hi! i have my sony eriction phone. it's loud speaker is not working.but when i fix head phone it work.can u give me solution for that.
Mar 07, 2008 | Sony Ericsson W850i Cellular Phone
Calling problems
Turn the volume on.. do u have it in the max volume of the phone? if not then thats the problem.. if yes..then the problem is the speaker.. on the same phone..and you should take it for a fix..
Apr 06, 2007 | Motorola Mobility RAZR V3
Calling problems
There is no problem with your phone's main speaker from where you can hear your ringer, tones and media files, including calls put on loudspeaker. The problem is the ear piece speaker of your phone.
Motorola Mobility RAZR V3i Cellular Phone Logo
62 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
