Question about Maytag Neptune Washer
NO DISPLAY AND LIGHT NEXT TO DOOR IS ON.
MY MAH7500 WASHER NO LONGER HAS ANY DISPLAY AND WILL NOT DO ANYTHING. THE LIGHT ON THE FRONT BY THE DOOR IS ON. ANY IDEAS
  • 62 Answers
You need a new control board.
Posted on May 12, 2009
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
My maytag Neptune washer mah7500 panel doesn't light up, but still works
Thought it was the door switch/grounding issues/loose wire, etc. Finally found that there was a bad capacitor on the circuit board. It was a 15 cent part that, when replaced, caused all the non-start/power failure indication issues to go away. I've included a picture of the bad part - you can see the slight bulge on the top of the capacitor and a little leakage. Hope this helps. 650c7b72-0a6b-4fe3-b776-b4d9dc5589c2.jpg
Feb 01, 2013 | Maytag Neptune MAH7500WH Front Load Washer
Model MAH7500 door will not latch
Clearly it's broken requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Oct 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
My friidaire washer will not start. The door lock light will not come on. The door closes properly. The error LOC comes on. Not sure what else to do. Doesn't seem to be any problem closing the door. Help...
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
seconds until ”LOC” is no longer displayed.
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
My maytag washer is giving an F H reading. I
http://laundry.manualsonline.com/manuals/mfg/maytag/mah7500.html
If the manual on this site doesn't help, you may want to try maytag.com for a manual.
as for the F H reading---you got me
Aug 09, 2009 | Maytag Neptune MAH7500WH Front Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Speed indication error
IT WAS NOT TURNING FAST ENOUGH.UNPLUG FOR 5-MINUTES AND RETRY.
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool duet 9400 Washer won't do anything?
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Dec 27, 2008 | Whirlpool GHW9400 Front Load Washer
LOC light is displayed
it sounds like you need a new door switch they cost a bout 15 pound you might get one off ebay don't for get model. number its in the door trim or on the front right bottom next to the programmer ok hope i helped you
Dec 28, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
151 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
