Question about Dryers
No heat in dryer
No heat on whirlpool gas dryer, I have cleanned all lint from the unit. All vents are clean and the unit has a solid front panel so I cannot see if the ingitor is working...
  • 10,865 Answers
If your dryer doesn't heat, check these:
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on May 12, 2009
  • Joe Hogan May 12, 2009
    Get back if I can be of further assistance.
I have a Kenmore 600 series gas dryer it has stopped heating. When you first turn it on it heats right up like it should then after jus a min the heat stops and it wont blow any more heat what could it be?
The majority of the time this problem is because the dryer vent is plugged. Remove the vent hose or pipe and clean it out, removing all lint buildup. Check the damper door where the dryer vents outside for obstruction. Make sure your lint filter and the area it goes into are clean as well. This will fix the problem 9 times out of 10.
Aug 02, 2013 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool gas dryer will start and run normal for 5-8 minutes, then flame shuts off and dryer cools off. Flame does not come back on.
Here's a few things to check that most people can do on their own. Keep in mind, that if you start taking the unit apart, you need to unplug the unit first. We don't want anyone getting zapped!
1) Obvious things first. If you have a propane gas dryer, make sure you are not out of gas! Go to the tank, lift the lid, look at the % gauge. If it's pointing at 5% or less, you may be empty or about to run out of gas. Order a gas delivery.
2) Another obvious tip. Check your lint filter. It may be so clogged that your dryer can't breathe. Clean it. Using a flashlight, look down into with the filter opening and see if there is a lot of lint still inside. If so, try using a small vacuum attachment and clean out lint. This applies to both gas and electric dryers.
3) Most gas dryers have either a small access panel in the front or at the very least, a peep hole. Open the panel or pop out the plastic peep hole cover so you can view the igniter. Turn on the dryer and watch for orange glow at the burner. If it does not glow, it will not light the gas burner. You may have a broken igniter and will need to replace it or have a new one installed. If you do it yourself, be sure to unplug the dryer and do not touch the very fragile ceramic piece of the igniter. You can confirm it is broken by locating the broken piece below where it is attached or noting it is missing a piece of ceramic on the igniter.
4) This tip applies to both gas and electric models. Another thing you can do is check for blockage in your vent. Unplug the dryer, and pull the unit out as far as you can to get access to the back of the unit. Be careful not to step on or kink the gasline. Pull the venting off the back of the dryer. There is usually a squeeze clamp holding it on. Clean out lint in dryer and from within the vent tube. Some cheap venting are made of expandable plastic or aluminum and can get squished to the point they restrict air flow. Make sure your vent is not collapsed and doesn't get squished when you push the unit back. Once you have cleaned and reassembled it, plug it in, turn on the dryer and watch for ignition. If it lights, go outside to the vent cap and check for lint there and make sure your vent flap opens with the hot air flowing out. Clean and adjust as necessary. If you have a long vent tube like I have on mine, then you should clean it out annually. I use a wind-up toilet snake and crank it around knocking lint loose from the walls of the vent. I can always tell when it needs to be cleaned again, when clothes no longer get dried in the first cycle. If you are unsure of, or unable to perform this task, then you'll need to hire a repairman.
Anyway, these are just the easy, quick fixes that most homeowners can perform on their own. If none of these solve the problem, you will need to troubleshoot further or hire a repairman. Hope this helps. Douglas
Sep 29, 2010 | Whirlpool Dryers
Dryer heating up initially, but after 3 minutes gas shuts off. Heating element ignites initially, then after three minutes the gas shuts off. The heating element glows again after 1 minute, but the gas...
I've compiled a list of a few things to check that most people can do on their own. Keep in mind, that if you start taking the unit apart, you need to unplug the unit first. We don't want anyone getting zapped!
2) Another obvious tip. Check your lint filter. It may be so clogged that your dryer can't breathe. Clean it. Using a flashlight, look down into with the filter opening and see if there is a lot of lint still inside. If so, try using a small vacuum2_bing.gif attachment and clean out lint. This applies to both gas and electric2_bing.gif dryers.
4) This tip applies to both gas and electric models. Another thing you can do is check for blockage in your vent. Unplug the dryer, and pull the unit out as far as you can to get access to the back of the unit. Be careful not to step on or kink the gasline. Pull the venting off the back of the dryer. There is usually a squeeze clamp holding it on. Clean out lint in dryer and from within the vent tube. Some cheap venting are made of expandable plastic or aluminum and can get squished to the point they restrict air flow. Make sure your vent is not collapsed and doesn't get squished when you push the unit back. Once you have cleaned and reassembled it, plug it in turn on the dryer and watch for ignition. If it lights, go outside to the vent cap and check for lint there and make sure your vent flap opens with the hot air flowing out. Clean and adjust as necessary. If you have a long vent tube like I have on mine, then you should clean it out annually. I use a wind-up toilet snake and crank it around knocking lint loose from the walls of the vent. I can always tell when it needs to be cleaned again, when clothes2_bing.gif no longer get dried in the first cycle. If you are unsure of, or unable to perform this task, then you'll need to hire a repairman.
Anyway, these are just the easy, quick fixes that most homeowners2_bing.gif can perform on their own. If none of these solve the problem, you will need to troubleshoot further or hire a repairman. Hope this helps.
Jun 12, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Kenmore gas dryer 110.70882990 runs & heats but shuts off at anytime during any cycle then i restart it & it may run until dry or may shut off a few minutes later ?
Jun 04, 2010 | Dryers
No heat
May 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
No heat gas dryer
hi look for the thermal fuse at the back where you cleaned . its a small plastic piece with 2 small blue wires . replace this part thanks
Oct 06, 2008 | Whirlpool Dryers
Whirlpool dryer
Hi thanks for you question . Check the voltage . best is replace the fuses . if breakers .re set. If still no heat lay dryer down front on floor. remove back panel, check the heater on the right . clean all lint in the dryer. and also clean all venting . thanks the appliance doc
Oct 04, 2008 | Whirlpool Dryers
Propane Gas Dryer (Whirlpool DUET Front Loader) not drying
huuum At your service!
Did this tech do some wash to the dryer and feel that there was no heat?
He was not a good tech
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 11, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Steam comes out of dryer after cycle and door is opened
Probably has a restricted vent. Go outside with dryer running and check air coming out vent. Should be a good blast...not just a breath. Clean out the vent and make sure it's not kinked. If it vinyl or foil vent, replace it! Also make sure lint screen is cleaned everytime.
Nov 16, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
107 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
