Question about Tomtom ONE GPS Receiver
Tomtom 1 lost memory card for tom tom 1 have been given a tomtom go memory card when i put it in tomtom go loads then goes blank screen or screen has stripes on it
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 171 Answers
You cannot use a sd card from another tomtom. The sd card is coded for each individual device. About the only thing you can do is to purchase a 1 gb card (no larger because it won't be supported). Insert the blank card into your unit and connect it to your pc. Go to my computer and see which drive the tt is. format the card and then open tomtom home. This will load your operating system back onto your card. I don't know if you can download a free map or not. Check the tomtom forums for more information concerning maps.
Hope this helps
Posted on May 29, 2009
My tom tom go stopped working. green light is on car cigarette lighter bit and on tom tom unit but screen wont come on it stays blank. it had just fallen off windscreen onto dashboard. memory card in...
Not sure which model year you have but check for a small reset button on bottom press and hold it with a paper clip or similar. Also try holding the power button for a minute to see if it reboots, try removing the memory card first. If it starts don't insert the memory card until the unit is off. If that still does not work click on the link below which will explain the reset in detail.
Thanks for using FixYa
http://www.ehow.com/how_5146905_reset-tomtom-go.html
Jun 02, 2011 | Tomtom GPS
I have got a binatone a350 but it has got tom tom one edition 3 loaded on it the thing is it comes on but when it gets to last screen all i get is a blue screen and it says NO MAPS. is there a solution...
I have loaded my Binatone B350 With a 128mb SD Card from my old Tom Tom Go which slots in perfect.
When i turn my sat nav on i get a blue screen stating
"WARNING SYSTEM REGISTRY KEY LOST"
The sat nav then reboots itself and goes to the main page
"BINATONE DRIVE LIKE A LOCAL" and then repeats itself to blue screen again. I have taken the card out and still get the blue screen. Any ideas on how to solve this please
Apr 23, 2010 | Tomtom ONE 3rd Edition GPS
My tomtom 1 xl is giving me a memory card symbol on the screen with a red cross over it !
do you have an sd card loaded?
if so and it hasnt been formatted for the tom tom then this can cause your issue, also if there has been an sd card in the device and then removed unexpectedly you will get the same issue.
hopefully this answers your query if so please rate my answer accordingly.
Thanks
Sep 14, 2009 | Tomtom One XL GPS Receiver
Tomtom not reacting
If you deleted your card your program is more than likely lost along with all of your maps. However never fear. If you had an account with tomtom you should be able to download a file from them that can update your sd card, But be aware they will probally charge you. Make sure to tell them that you were downloading one of THEIR updates.
Aug 22, 2009 | GPS
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Flashing X on start up
If you have a memory card in then remove it press the reset and try to start up again.
This problem is usually the way the memory card is formatted.
I solved mine by doing a search for "format tom tom memory card" or "format tom tom SD card"
After I had done that I backed up my TT then put the card in and then restored to the card and all good from there on.
Mar 15, 2009 | Tomtom GO 920 GPS Receiver
Tom tom one Xl wont load
Hi,maybe that the memory card is knackered! (tomtom ones are poor quality and slow) Have you got a spare card that you use in a camera maybe, if so format it using fat 32 on your computer and then copy and paste all your files one by one onto it. I this works I would recommend a sandisk ultra 2 as a replacement card, worked for me!
Feb 24, 2009 | Tomtom One XL GPS Receiver
Tom tom Western european map
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Memory card for tomtom
Did you try reformatting the card?
Jun 09, 2008 | Tomtom ONE GPS Receiver
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom ONE GPS Receiver Logo
141 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
