My olivia 47inch TV is on wall HDMI cables in back --inaccesable am using standard terminal i feel that the recepticle is bad
  • 1 more comment
  • byronyelapa May 12, 2009
                model # also on back---thing to heavy to move alone ok i have says2 seriesLCDTVs
                247FHD ---i think.  the cable hangs down, is heavy needs to be tighter or otherwise
              adjusted  new cables i think would have same terminal---crazy glue???????---earn your 10 bucks!!!!!!!!!!!   byron
                       i paid to have HDTV, NEED those cables---how can i keep them from falling out
                        the other ends stay put,  the problem is on back of TV---and i can not reach the receptacle
                      without taking the TV off the wall.---need two men to do that-------unacceptable
                                                      byron
              i have the manual--- no trouble shooting section and if it did i doubt this question would be answered there  if thats all you can do, i reject your answers   sincerely  byron
    Brigadier General:
  • 8,619 Answers
Hi
Try using the RCA component cables instead of HDMI cable and check if that makes a diffrence. Also try and check if the cables are connected firmly.
Please elaborate your issue and also tell me the model number of your TV so that i can provide you with model specific information. Please do revert for further assistance.
Thanks
Rylee
Posted on May 12, 2009
  • Rylee Smith
    Rylee Smith May 12, 2009
    Please check the On Screen Display (OSD), make sure the appropriate input source is selected, e.g., cable or satellite, DVD player, VCR, game console or DVR. Set it as DVD player and try connecting your DVD player instead of cable or sattelite.
    You can also look at this link for connections and other cable related issues---
    Olevia LCD 247FHD Series 2 Instructions Manual
    Please do accept this solution and revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    You can use cable ties and adhesive cable hooks to hold your cables in place, it will not let your cable fall. You can buy these clips and ties from this link---
    Adhesive Cable hooks
    You can select other similar cable hooks and ties from this link as well--
    Other Adhesive hooks
    Thanks
    Rylee
47 LCD TV HDMI 1 and HDMI are both not working, error message no signal. how to solve this problem?
I have had HDMI cables to just all the sudden go bad,, try another one.
Feb 06, 2015 | Televison & Video
How do I connect my DVD player
Use an HDMI, or AV cable. HDMI is better.
Sep 21, 2014 | Televison & Video
I have a Mitsubishi wd-65831 I just got a new cable box with hdmi hook ups it's jus it I plug everything in the cable pops up briefly then goes to black screen any ideas?
try using a hdmi cable that terminates into rca/ audio video standard then plug the hdmi end to the source and the rca to the dvi or componenty.ypb and u are good to go but ensure u select component on your tv
Jul 12, 2013 | Televison & Video
How can i unlick philips hotel tv 32hfl5662l/f7
How to switch your hotel Phillips 32HFL5662L/f7 to HDMI if you need to.
(I'm stuck in St Johns, Newfoundland, miles from the downtown....I must be bored)
1. You will need a serial DB9 M-F cable, your PC with a serial port and a terminal program like Hyper Terminal or Putty
2. Set your baud rate to 115200, n,8,1
3. Unplug the AC adaptor connecting the little smart box on the back of the TV. The TV may plug into this adaptor as well, so just plug the TV back into the wall. If you do not, the LCD TV will try to switch back to cable after you select HDMI.
4. Power on the LCD TV and you should see data on the PC screen in readable text.
5. You must send a carriage return after each command <cr> (the enter key on your PC)
6. Use only small letters (no caps)
i - info
u,d,l,r - Up, Down, Left, Right
p - PIP window toggle
To set to HDMI use the following sequence:
i <cr> (menu)
d <cr> (down)
d <cr> (down)
r <r> (right)
then use 'd' and 'r' to select the right input
Jun 13, 2012 | Philips Televison & Video
Can i hook my 47inch tv to the monitor
You can't hook you TV to the monitor itself, rather the computer.
If your PC has a wide white connector (DVI) that is supplying signal to the monitor, you could use a DVI to HDMI adapter cable to connect your PC to your TV. This is also possible if your PC uses a small blue connector with 15 pin holes (VGA) by using a VGA cable to connect your PC to your TV.
Mar 17, 2011 | Acer AL1916W 19" LCD Monitor
Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
Mar 10, 2011 | Philips 32PF7421D 32 in. LCD HDTV
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Jan 10, 2010 | RCA HD52W58 52" TV
LC32OEM9 says Not Supported Format on HDMI Input. It worked when we first hooked up the TV. Then it started working sporadically now it very very rarely works and when it does it only works for maybe 15...
I'm thinking the Comcast DVR box maybe putting out weird HDMI signals and the TV can't translate it. I would call the Comcast people on this one.
In the meantime, I would try finding another source the uses a HDMI cable to rule out the TV as the problem. Basically, testing the TV to see if the problem still happens when you use something else than the Comcast box. Try a Blueray player, Playstation 3, or Xbox. Just something that uses a HDMI cable.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
