Question about Alpine MRD-M1005 Car Audio Amplifier
Repair assist needed
Q306 is very hot-also replacement is same.   zd903 is shorted out I need to know the value???
  • 203 Answers
I need you to be more specific, what do you mean value? You mean the price of the ZD 903?
Posted on Oct 21, 2007
After replacing the stks you need to perform convergence adjusment procedure.
If Stk keeps burning out then replace convergence board.
Sep 03, 2008 | Sony KP-46WT500 46" Rear Projection...
Hisense LCD32V77
it must be a power supply malfunction; if you`re not a tehnician , please contact the nearest repair shop.
Nov 18, 2013 | Vizio L32 32 in. LCD HDTV
Im working on a RCA ITC222-it has 3 chirp problem with burnt CL031. Unfortunately RL106 is burnt (I need value)and, FL100 is open (I need current rating)and finally, DL032 and DL033 are shorted (I need...
Cl031 is the sfaety retrace capacitor check DL030 an the HOT trans they are most likley blown as well. Usually if anything other than the Hot and DL030 are blown the entire deflection board will need replacement. Its also best to check all three of the CRT necks to be sure none are cracked and broken on the CRT necks . Unfortunately several designs of the deflection components had different parts although the deflection boards will usually interchnage bewteen the ITC222 chassis sets. The ITC222A will not interchange. has replacement parts and boards and can also assist with part numbers that you require.
Oct 14, 2011 | RCA HD52W59 HDTV Projection Television
I have 2 pcs panasonic Fan buy from 2005 problem speed , please advise how to repair , what component need to replace , My friend also find same problem , why panasonic fan very easy defect
You are reporting about the lack of speed to your fans I thinks and posts this solution. Normally lack of speed will be due to faulty capacitor. In most cases the value of this capaitor will get reduced. Replace it. Its capacinace value will be markde on it. After replacing the capacitor; till the speed does not get improved, make sure that either start or run windings in the fan has shorted winding in it. If this is the case, the body of the fan will get hot, and a hum sound also will be present. First replace the capacitor and check. If you want any more assistance from me get me by Fixya. OK.
Jun 25, 2011 | Panasonic Dryers
Shower gets too hot the thermostat does not seem to control the heat
On all showers, there is a mixing valve behind the wall. With out knowing which type of faucet I can't give proper details, but generally if has just started on its own to do that, the vavle either needs cleaning or replacement. Most valve manufacturers offer lifetime replacement parts, I know Koehler and American Standard do, so parts shouldn't be an issue. They can also walk you through minor repairs as well. If you need further assistance let me know and if I can get the model number of your fixture, maybe download the schematics, and assist you more.
Jul 15, 2010 | Home
Flashing red light on power indicator, TV will not power on. Have tried several outlets and none work.
The blinking light indicates that inside the power supply circuitry, there's a shorted diode(s), open resistors and bulging or leaky capacitors.
This repair might be a DIY if you know how to solder and desolder thru-hole parts and surface mount as well the use of a multimeter to measure the values of resistors, and good or bad condition of diode(s).
I can repair it for an affordable price.
Let me know if you require further assistance.
Jul 13, 2009 | Akai LCT2701TD Television
T.v. shuts off, code 24
The safety circuitry of the TV will shut it down when it detects a problem with the TV. The code is a starting point for a tech to start looking for the problem. The 24 code is an indication of vertical deflection failure. Mitsubishi is known for not having parts for their TV sets after they get to be 6 or 7 years old. They also make consumer repair of their TV sets difficult since they will not sell their parts to anyone but a registered repair facility. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. Heat is the number one enemy of electronics, and these sets operate hot. This model of TV has over 3,000 parts which include millions of transistors inside the integrated curcuits. Over time the capacitors will change value, leak and become defective. Resistors will change value and burn. This will cause other components to become defective. This can has a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. I expect the parts needed will cost less than $50 dollars unless it needs a board replaced. Most shops will charge about $350 to repair the set if they can get the needed parts. Small TV repair shops will often charge less than a large repair facility.
May 09, 2009 | Mitsubishi VS-50607 50" Rear Projection...
View sonic Optiquest Q7B-3 comes on for a second then black
Don't know if this will fix your problem, but my monitor did the same thing. If you look on the bottom of the power supply board, you will find Q305 and Q306. They are probably both shorted. I replaced both transistors and the capacitor C305 on the top of the same board. The capacitor was open. After I replaced the parts it is working again. Look with a magnifying glass and make sure there are no bad solder joints. The only place I could find the transistors were at Make sure you order the 2SC5706. It is an exact replacement.
Dec 11, 2008 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
Alpine MRD-M1005 Car Audio Amplifier Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
