Question about Craftsman Convertible 25cc. Gas Line Trimmer
Chainsaw i have fuel coming out of my muffler
  • lgarza2058 May 12, 2009
    I took the carburetor apart and everything seems fine but now i think i may be putting the gaskets on backwards does anyone have any instructions on how to put the gaskets back together
  • 86 Answers
Most likely you have a hole in the diaphragm inside carburetor on needle is sticking remove carburetor and clean install carburetor kit.
Posted on May 12, 2009
  • Jerry Cramer May 12, 2009
    You have 4 gaskets, diapram side the one with metal ring on it and the plain gasket .Gasket first then diapram metal toward carb.Other side has two gaskets also one is rubber or sometimes plastic that one goes toward carb.first then you install other one.
PP2075 starts with the muffler off but not with it installed. Muffler is clean - screen is clean - center facing the right way. Good fuel etc....
mufflers can be clean and still not work properly. After removing muffler and unit runs then change your muffler and clean your exhaust port while doing so
Sep 18, 2014 | Garden
Why does fuel come out of the muffler when I pull the rope to start it?
The carb is not working properly. Have it rebuilt, od buy a kit and do it yourself.
Sep 05, 2014 | Garden
Craftsman 18" chainsaw runs but dies when I press the throttle, new carb and fuel lines low and high speed set at 1 turn .
remove the muffler and run it after seeing that it runs good open the muffler and clean the screen inside
Sep 27, 2012 | Craftsman sears 18" Chain Saw Chain (...
Wont start
check for spark check for fresh fuel mixture check for the fuel filter being connected to the fuel line if all that is good remove the muffler if it runs with the muffler off open the muffler and clean the screen
Sep 08, 2012 | Garden
What causes a husqvarna 350 chainsaw to spit fuel out of the air intake
remove the muffler and try it if ok open the muffler and clean the screen inside carbon builds up and restricks the exhaust flow
Aug 31, 2012 | Garden
Replace muffler on poulanpro 262 42cc
there is two bolts on the front of the muffler that hold it on remove the bolts and the muffler will come off most muffler problems are carbon build up inside the screen it is made to open to clean the screen
Jun 30, 2012 | Garden
Makita dcs6401 chainsaw stopped in use want restart
remove the muffler and see if it starts if so open the muffler and clean the screen inside
Jun 10, 2012 | Makita DCS6401 20 20",64cc Chainsaw 2...
McCulloch mcc1635a chainsaw won't run. Acts like it is starving for fuel.
take off the muffler and try it there is a screen inside that get plugged up with carbon you can open the muffler to clean it
Jun 03, 2012 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
Chainsaw wont fire
Is the spark plug wet (inside after trying to start it)? If dry, the carburetor isn't delivering fuel into the engine. Check the muffler to see if it is plugged. Is the carburetor firmly attached to the engine? Fuel and spark at the right time makes it go! Try squirting a little fuel into the carburetor throat. Might be loose screws on carburetor assembly.
Jul 03, 2009 | Garden
Fuel is coming out of my muffler on my chainsaw
your air fuel ratio is off, that is unburnt fuel coming out.
you need less fuel, turn knob down at carb when running and adjust till runs good and no fuel comes out
May 12, 2009 | Poulan Pro Chain Saw 46cc 20"
Craftsman Convertible 25cc. Gas Line Trimmer Logo
100 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
