Hi i have a 2001 Leganza deawoo and i need the code to unlock it. I try everything and i cant get it can you help me.
  • 91 Answers
It will be in your owners manual, if not conract daewoo and give them you v.i.n and they will give you your code
Posted on May 12, 2009
2001 deawoo laganza egr code
If you get the carbon etc out you will be okey
Wouldn't you need to have the valve off to clean
passages?
Oct 02, 2012 | 2001 Daewoo Leganza
My 2001 deawoo laganza has no heat and when you try to switch vents, the control knob moves, but will not switch to floor or defrost, just blows out front vents.
Your control doors under the dash are not operating. Don't know if they are cable operated or vacuum operated. You have to get under the dash to find the problem, and maybe pull out your control assembly on the dash to see the problem. Sorry, not much help.
Oct 06, 2011 | 2001 Daewoo Leganza
How much do you torque a cylinder head down on a deawoo leganza
step 1 25 ft lbs.
step 2 an additinaiol 90 degrees
step 3 an additinoal 90 degrees
step 4 an additional 90 degrees
Aug 17, 2010 | 2001 Daewoo Leganza
Unlock radio codes for 2001 daewoo leganza
If you lost your stock radio security code and have disconnected the battery, your radio will need a code before it will work again.
More than one person has had good luck with 2253 but also try these:
1156, 3116, 3451, 2152, 4362, 4316
4316, 2152, 4513, 4362, 1156, 2145
6451, 6361, 5624, 5241, 3346, 1165
3241, 4524, 5436, 5813, 3265, 7348
2453, 3462, 3251, 5445, 8253, 2253
2346, 4853, 6645, 5253, 1325, 4136
3116, 3221, 2151, 5312, 2654, 4315
Jul 25, 2010 | 2001 Daewoo Leganza
Deawoo Lagaza Stalling
Is it an automatic? It could be low on tansmission fluid. Check fluid level with transmission dip stick, red handle, lift to unlock the handle and pull stick out. Is it cherry red in color or brown? It should be red and NOT smell like burnt toast. Carefully fill to appropriate level, do not overfill. Thats the easy part, now you have to determine why it was low in the first place.
Jul 06, 2010 | 2000 Daewoo Leganza
2001 deawoo leganza code p0401
The egr valve has insufficient flow, take it off, or have it taken off, and clean the under side of it, there might be a port clogged, or the diaphram inside is leaking, in which case the valve will need replacing.
Jul 30, 2009 | 2001 Daewoo Leganza
Radio code
contact daewoo give them your vin and they will give you your code
May 12, 2009 | Car Audio & Video
Hi can someone please help me fine a radio code unlock for a 2001 daewoo leganza.
Pull off the trim around the radio and look in on top of the radio. I have found Daewoo radio codes stamped on a tag on top of the radio.
May 12, 2009 | 2001 Daewoo Leganza
Help
theres a couple things for this
one the code is located in glove box
the code is listed on sterio
three you will have to go to dealer get it recoded back but there supposed to give you new code
Nov 27, 2008 | 2001 Daewoo Leganza
61 people viewed this question
 Grubhead
Grubhead
