The monitor will not support my graphs card
Your monitor envision will not support my graphs card
  • namley May 11, 2010
    If you have onboard video, disconnect the video card and boot up the computer as normal
    there is a few things you want to take into consideration.
    The native resolution of the monitor.
    the refresh rate of the monitor.
    now the normal refresh rate of an LCD monitor is 60Hz.
    CRT monitors range, from 50-120Hz
    Here is an easy way to understand refresh rates. Have you ever noticed while watching TV, if there is a computer monitor in the scene, you notice black lines moving from either top to bottom, or vice-versa.
    That is the screen refreshing itself. So it can display you're picture.
    Now if the monitor is not capable to hand those refresh rates, it won't display a picture, and if it has enerstar built into it, it will shut itself off.
    Boot the computer into safemode with the onboard graphics. Check the refresh rates in safe mode, also write down that the screen resolution is, and the refresh rate.
    All of those things can be found from the display properties.
    How to boot into safe-mode on a windows NT system, hit F8 while the computer is booting (before the windows logo)
    select Safe-Mode out of the list.
    How to access the display properties
    right click on the desktop image, select properties out of the list.
    Now re-insttall the graphics card, boot into safe mode. And Change the settings.
    Nomal settings for a desktop PC and a monitor are
    1024px * 768px - resolution
    72Hz for CRT or 60Hz for LCD
    hope this helps
    good luck
    Problem Solver:
  • 15 Answers
Get new monitor or... reduce the settings of the video card to a setting that the monitor can handle. Boot to Safe mode (tape F8 key every 2 seconds when booting up) which will get you into safe mode which is the lowest setting of the video card. If you have no video in safe mode you have other issues. Once you have video in safe mode slowly incress the video settings. If it goes blank just wait (no keystrokes or mouse movement) for 30-50 seconds and it will revert to the last good video settings automaticaly.
Posted on May 12, 2009
My laptop LCD screen is FUBAR and in order to use my computer I have hooked it up to an Envision 19" LCD Monitor. If I start Windows Vista in Normal mode , it does not recognize the Monitor. Pressing...
I would go ahead and boot into safe mode where you say it does work and then take a look. See how it detected it...ie look in device manager and see if it picked it up by it's true brand/type etc. Check the settings both of the display and on the envision itself. Check the resolution selection. It's probably picking it up as a lower res. but when it boots into reg windows may be trying to run at full res and perhaps that's what it won't do. Check to see what driver it's using. It may need the specific driver from envision and not the generic driver. It could also be a bad pin on the envision itself.
If you have another computer you can hook it up to, do that to make sure the envision is working. That way you can deduce which is the problem, the monitor or the setup in your laptop.
Jul 10, 2011 | Envision 19" Widescreen Flat Panel LCD...
Will not power up
try to disasemble ur video card then put it back again the open it...
Nov 08, 2009 | Envision G22LWK 22" LCD Monitor
Envision 19" Monitor is "ghosting" . It is about 3 years old. Just starting doing it. Nothing has really changed on my computer. Thanks for any help.
Try reseating the input cables. If that doesn't work then you could try a new input cable. Updating your video card drivers might also do the trick.
Sep 23, 2009 | Envision 19" Widescreen Flat Panel LCD...
Monitor is plugged in but not monitor does not come on.
You might have a bad video card. Try buying a PCI slot card to replace your intergrated card and see if that works. PCI Cards are really inexpensive.
Sep 01, 2009 | Envision G918W1 Monitor
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
OSD locked on ENVISION Monitor
turn of the monitor then press the menu
Mar 13, 2009 | Envision H191W Monitor
All pictures appear wider than they really are
You may have to match up the video card settings with the monitor settings to get the correct resolution setting. Try adjusting the resolution of the graphics card to match the setting for the monitor. If this does not work you can call, Envision customer support at this telephone number : 1-888-838-6388. They should be able to help you get the correct setting for you set-up. I hope this information helps you with your problem.
Dec 03, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
The desktop no longer extends to the left side at the 1440 x 900 at 60 hrz resolution. There is a black vertical stripe on the left. I don't know what happened. I've set the horizontal position at zero,...
This problem,could be a problem with the monitor or the graphics card. You need to test your computer with another monitor at the same setting to see if the graphic card is having a problem with the setting. Also test the monitor on another computer with the same setting and see if you still get the problem. You can also try using a different graphics card in your computer to see if the graphics card is having a problem. Setup the new card for the same settings and see if you still have the problem.The customer support telephone number for Envision is .1-888-838-6388. Their customer support website is. www.envisiondisplays.com. They should be able to help with your problem.I hope this information helps you with your problem.
Jul 30, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
