Question about Pentair Wf 6 1.5hp Whisperflo Inground Pool Pump
Whisperflo pool pump is getting hot - Pentair Wf 6 1.5hp Whisperflo Inground Pool Pump
  • 59 Answers
Hot in referrence to what. this pump will get so hot it will cook an egg on normal operation. is it kicking off on hi temp? if not I would not worry about it.
David
Posted on May 25, 2009
Motor clicks off after getting hot?
This is a normal function of any pump. When a motor gets too hot it has a thermal cut-off inside so it won't burn up the pump.
Once the motor has cooled down it will come back on.
Look around the motor to make sure it has plenty of ventilation. If it does and the motor keeps shutting down on you I would replace it or take it to a motor repair shop and get it looked at.
There will be something wrong with the motor and that point.
Rod
U S Parts Center
Apr 20, 2014 | Pentair Whisperflo 2 Hp Ur Pool Pump Wf28...
Removing impeller from OJ800 water pump
The impeller has a reverse thread locking screw through the center. You can secure the motor shaft by putting a 9/16 open end wrench on the other end of the shaft, which is under a cap in the middle of the rear of the motor.
Check your seal plate carefully. Whisperflo is a great pump but they don't take heat very well. It is very common for the seal plate to also be damaged when the pump runs hot, particularly the lower inserts where the bolts screw into.
Jan 05, 2014 | Pentair 1 hp WhisperFlo InGround Pool Pump...
Whisperflo pump exploded
I am as of yet unaware of any means in which a pool heater will make a pump explode, but am intrigued, certainly. Actually, I have never heard of any pump "exploding".
I would assume that there must have been some restriction that caused some sort of failure. Can you be more specific about what kind of damage occurred?
Mar 15, 2013 | Pentair Whisperflo 2 Hp Pool Pump Wf8...
Pentair WhisperFlo 1hp, 230v, Dual Speed won't start in morning
If the high speed side of a two speed pump will not operate it is because there is a problem with the windings on the high side of the motor.
You will need to either take it to a motor shop and have them fix it or replace the complete motor.
RodUS Parts Center888-521-6813
Feb 27, 2013 | Pentair Dual Speed 1hp Full Rated 230v 60...
Whisperflo pump super hot
motor overheating replace motor or pump
Aug 26, 2012 | Pentair 15 Hp Superflo Swimming Pool Pump
Connecting Electrical to Pentair SuperFlo Pump
if 220 volt ok from factory hot to L1 2nd hot to L2 green to ground or case if 120 volt see side of motor for wires to be moved for low voltage
Jun 26, 2012 | Pentair Wf 6 1.5hp Whisperflo Inground...
Instalation
this should only be 220 volt hot to L1 2nd hot to L2 green to ground see side of motor for wiring
Apr 26, 2012 | Pentair 3hp Whisperflo Pool Pump In -...
When I turn on my pool filter with a Pentair WhisperFlo 2 hp pump, the psi has jumped from 18 to 30. There's nothing visible in the baskets in the skimmers or in the WhisperFlo. Where could the resistance...
If your pressure has gone up, the problem will be on the discharge side of the pump. First, make sure that your gauge is not malfunctioning.
Next see if all valves after the pump are set properly and that the three way valves or backwash valve are not broken inside.
Is this helpful?
Gary
Feb 28, 2011 | Pentair 2 hp WhisperFlo InGround Pool Pump...
My 3 year old pool pump whisperflo is running a louder. What do I need to check?
Loud operation is an indication that the bearings need replacing. A local small motor repair shop can probably get it done for $70 or less. Call around...
Apr 18, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Whisperflo Pump 1.5 Hp problem
The pump is probably fine the motor is the problem. If it just hums it might just be the capacitor on top of the motor. Don't know how long it sat there not able to start. Was the motor extremely hot ? If it got too hot may have damaged the motor. Motor is replaceable without replacing the pump head.
Sep 30, 2009 | Pentair Wf 6 1.5hp Whisperflo Inground...
Pentair Wf 6 1.5hp Whisperflo Inground Pool Pump Logo
286 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
