Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Trouble code ch6 oil on hour meter
I was mowing and the motor quit. I am getting the trouble code ch6 oil on hour meter. I just changed oil in the mower about 2 hours of use ago. The oil is full. When I turn the key on there is a click like a solenoid is tripping.
  • 86 Answers
Sounds like your oil low switch is either bad or maybe wire was knocked off when changed oil.
Posted on May 12, 2009
SERVICE REMINDER/HOUR METER
Service reminder shows the total number of hours the engine
has run and flashes to indicate that the engine or mower needs
servicing. When service is required, the service reminder will
flash for two hours. To service engine and mower, see the
Maintenance section of this manual.
NOTE: Service reminder runs when the ignition key is in any
position but “STOP”. For accurate reading, be sure key remains
in the “STOP” position when engine is not running.
Posted on Jul 01, 2009
  • 118 Answers
Use some electro spray in the ign. key hole and turn the switch off and on a few times with the battery disc. this should help your problem. Luck to ya.
Posted on Oct 11, 2013
I have same mower. The clicking solenoid has nothing to do with the hour meter. Mine started doing that a long time ago. The ignition switch is flaky. Sometimes it doesn't make good contact when you turn the key. Hold the brake pedal down and keep turning the key on and off until the engine starts to turn over. I have to do it on mine every time I start it.
Posted on Jul 23, 2009
17hp briggs and stratton shut down while mowing and won't restart. gas in tank is bubbling
Sounds like a blown motor but maybe not.I can take a look at it ifr you like/
Apr 14, 2013 | Garden
How to reset hour meter on encore mower
As far as i know there is no re set for the service minder/hour meter, it will be a replacement.
Jun 09, 2012 | Garden
What does the hour meter on my mower actually tell me? It is flashing between hours of usage and chg oil. I changed oil and filter about four running hours ago. I cut grass for a few hours and then...
Hi, the meter flashes oil change when they are due(at pre-programed intervals) and will stop flashing two running hours after flashing starts. The hours that are showing are total running hours from new. Hope this helps, regards Phil.
May 31, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman DGS6500 Garden Tractor 24 HP Kohler engine. Messages says CH6 Oil - what does it mean? Oil is full and new.
It means change the oil. It will come on every 50 hours regardless when the oil was last changed, then go off after a few hours.
Aug 28, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
I have a tecumseh 8hp on a snapper handlebar rider. bought it used 2 weeks ago, got it home mowed for about 1 hour and it quit. decide to give it a tune up. noticed the coil wire was almost burnt in half....
If plug is dry than you are not getting fuel to the plug something is plugged up in the carb clean it thoroughly and make your coil gap is correct. But I would lean more towards the fuel not reaching the plug.
Jul 18, 2010 | Garden
I have a cub cadet lt1550 and the oil light is blinking and a ch6 code is flashing. checked the oil and it is full. just wanted to know if something is wrong or that is a reminder to change oil and if it...
The mower is programmed to remind you to change the oil every 50 hours. It will continue blinking for 2 hours. It will begin blinking again at 100 hours and every 50 hours after that. There is no manual reset.
May 20, 2010 | Briggs & Stratton Garden
Ch6 Oil code
Hello, W/D here.
What you are actually getting is Chg Oil (change oil). This is preprogrammed in, as a reminder for you to service the engine. It will go back to the hour meter mode after about 1 hour of additional runtime. If you have changed your oil and filter, there is nothing else to do. The oil and filter need to be changed regularly. If the oil breaks down in your engine, it will lose it's lubricating properties and the engine will seize up.
Best regards, --W/D--
Aug 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
CH6 OIL code
it should reset itself automatically after about an hour running. it is just a reminder to change the oil and doen't affect operation
Jun 29, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
1,926 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
