Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
I own a Sears 42 inch B&S 18.5 31P777 engine
I own a Sears 42 inch cut with a B&S 18.5 31P777 engine that suddenly quit after two rounds around my acre yard. It died and I was able to start it once and then the thing only barely ran and blue somewhat black smoke came out of exhaust and oily gas blew out of round gizmo where the fuel comes from the tank. Also a rubber hose came loose spraying fuel from carb. Do you have any Ideas on this one? I would appreciate any help you can give
Ed from Oklahome
Hi I have a sears tractor with a briggs engine 24hp, the motor has been running well, but know it is bending ext. push rods, hard time to set the valve , could the problem be with the tappet-valve????
thanks jeff from ottawa,ca jeffkeyuk@live.ca
Posted on Jul 15, 2009
  • 13 Answers
Okay, here's the main problem. The engine itself (literally the engine with a bare crankshaft) is produced by Briggs. 99.9% of the time, everything else is supplied by the equipment manufacturer, although a couple get specific enough to have Briggs equip the tank. Not many, and they are few are far between. So you're dealing with the carb (Briggs) and more than likely, the fuel tank and lines supplied by Craftsman (I assume that's the make since it's a Sears).
It sounds like fuel has gotten into the engine, thus the black smoke. Not sure why in the world that would cause the lines to come off. Check your oil first and see if there is gas in it. You might need to replace the fuel lines, check your owners manual for the rider and see if they have a parts list in the back, anything they did not supply will say something like "see engine manufacturer". If the hoses are there, you can get them from them. But the carb may also need cleaned out or, possibly, rebuilt. Rebuild kits are generally pretty cheap and available directly from Briggs with the Model, Type and Code numbers from their site.
Hit me up if you need any more info.
Posted on May 14, 2009
Yard works 4.5hp 42" cut lawn tractor cuts fine when mower deck is up on 4, but when it is lowered it cuts out and won't cut the grass.
4.5 hp will not power a 42 inch deck any way you cut it quite likely the blades need sharpened real bad .motor needs to run fast when tryng to cut also as that throws the grass out of the deck
May 27, 2015 | Garden
Made loud noise than just quit
remove the cylinder head and rotate the engine over
Sep 17, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I GOT A SEARS CRAFTMAN riding lawnmower 17 hp 42 inch cut kohler engine.and when i start oil come out of my exhaust what causes that
Either over filled with oil, valve stem seals leaking, engine breather blocked, or the engine is badly worn.
Mar 13, 2012 | Garden
I have a craftman 42 inch silver lawn tractor and would like to change the oil what typpe do i use
Briggs & Stratton engines use 48 ounces of SAE 30 oil & Kolher engines use 2 quarts of 10w30 oi. Be sure not to over fill the engine will smoke like a banshee!! Verify the level with the dipstick. Oil can be gotten from Sears or from your favorite auto parts store.
Oct 28, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed My mower is a 42 cut and leave a row in the middle of the cut
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Sep 30, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I would like to replace the mulching blades on my Sears Craftsman riding mower with regular cutting blades. I can find plenty of sources for new mulching blades, but not cutting blades. My mower is a model...
The straight blade for the 42 inch mower is 138971.They cut better and are easier to sharpen and you will need them if you use a gass catcher. If you do not want to use sears for parts you may be able to find good deals on ebay.
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a sears 19.5 42in cut - Model #917.270810 need to find part for a spindle (I think it is where the blade attaches to.
sears has a appliance and tool repair center some where in your area hopefully.with your model # you should be able to order parts from them no problem.try a web search for appliance repair center for sears in your area........gd lk. chris.
p.s spindle is indeed the drive shaft for the blade.
May 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
May 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
662 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Roland W VanLue
Roland W VanLue
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
