Question about GE DBXR463EBWW Electric Dryer
Unbalance drum - GE DBXR463EBWW Electric Dryer
  • 460 Answers
I need the brand n serial# please to better assist you
Posted on May 12, 2009
My GE washer GTW460NMKwww, the drum will not balance itself when going into final spine cycle.
Are the clothes evenly distributed inside the drum and the washer not overloaded? The drum is not self balancing, you must take care when loading it to even the weight distribution
Mar 01, 2017 | GE Washing Machines
Makes noise when agitating
quite often coins and other objects get washed lodging between inner and outer drum . Check there
Aug 11, 2015 | Washing Machines
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
Apr 25, 2015 | Miele Washing Machines
How to balance a frigidaire washer?
Hello - Are you speaking about being balance without the leveling legs? Is the unit located on complete level ground? Or is the washer tub loose and unable to move? If you are referring to the drum, try rotating it manually when it is turned. If you notice that the drum is not balanced and cannot rotate freely, I would suggest contacting a professional so they can move forward accurately. Washer may possibly have a faulty bearing, unbalance drum or pulley issue.
Dec 06, 2012 | Frigidaire Washing Machines
Tub is loose
Hello Rob - Try rotating the drum manually when it is turned. If you notice that the drum is not balanced and cannot rotate freely, I would suggest contacting a professional so they can move forward accurately. Washer may possibly have a faulty bearing, unbalance drum or pulley issue.
Oct 06, 2012 | Frigidaire ATF6000ES Front Load Washer
Drum hitting sides of machine in spinning cycle (unbalance)
It sounds like you may have to many clothes in it. Try to remove some or reposition them. Sometimes the clothes get pushed to one side of the drum during the spin cycle and all of the weight to one side is making it off balanced.
Dec 27, 2010 | Hoover Washing Machines
Have DE progamme fault...
dE - Door (Front Loader) or Lid (Top Loader) Open Error = Close Door / lid
If error persists, check:
  1. Make sure the load is not too large - try taking some laundry out and see if the error persists.
  2. Wiring harness
  3. Door / lid switch assembly
  4. Unbalance switch
  5. Circuit board for defects.
  6. Check Drum retainer springs are situated correctly and are correctly tensioned.
  7. Make Sure Drum stabiliser struts are not misaligned or broken.
Repair / Replace faulty part.
Nov 06, 2009 | Samsung Washing Machines
Zanussi 1600 aquajet not spinning
It could be the unbalance control that feels that the clothes has too much unbalance, or the brushes in the motor is worn, and need to be replaced.
Nov 19, 2007 | Zanussi FJD1666W Front Load Washer
My washer shows UE code
UE code is an "unbalance error". Believe it or not, it is possible to unbalance a front load style washing machine. Usually caused by trying to wash smaller loads where the drum spins to try to distribute the weight evenly. With less laundry, you cannot distribute enough weight evenly around the drum and sometimes will cause an unbalanced load. If your problem is not a simple loading issue, it could be the balance sensor, loose wiring, or possibly the main control board. I hope this helps.
Apr 21, 2007 | LG WM-2077C Front Load Washer
GE DBXR463EBWW Electric Dryer Logo
48 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
