Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Stalling I have changed the oil, spark plug, filter, and gas. My lawn boy silver series still will not remain running very long and must be primed repeatedly to start, even on warm start.
  • williamgraes May 12, 2009
    i have not replaced all the items as pearlsj77
    but my stalling problem sounds very much the same
    my lawn mower is a push tecumseh
    the model is a 22117X92B
I have same mower and just fixed what seems like a similar problem description. I had gone down the fuel system route and the symptoms just didn't add up. Stopped abruptly w/o sputtering once I reached warm-up temp. Replaced the solid state ignition (34443C now part number 3444D). Problem corrected and just mowed my 1/3rd acre w/ no issues.
Posted on May 14, 2009
Can you use a champion spark plug rdj7y in 6.5 silver series lawn boy mower
Anthony you can use any kind of spark plug brand as long as its the same size. Sometimes they have a longer sparking element and this will catch on the piston. Just be careful.
Sep 10, 2013 | Champion International Lawn Mower Champion...
After trying to run a water hose through it to clean my Toro 650 190 CC lawn mower has refused to start for me, let me add before the hose I turned it upside down to get out excess grass, Now I've...
Only tilt a lawnmower backwards toward the handle end (spark plug end raises) Other ways move the oil around to places it doesn't need to go. Now you probably have gas in the oil....check it or change it (milky looking or smells like gas..contaminated...might need changing anyway...You probably will have oil in the carb and it will blow smoke...You probably filled the oil breather with oil and it will drain down...causing smoke also. This was the wrong thing to do A 2 year old unit should be mechanically sound..Check the air filter, spark plug and carburetor for oil fouling. Remove the bowl on the carb to help get some of the oil out...it will leak gas when you do.
Jun 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Lawn Boy mower will not start. New gas and plug.
Is the plug getting wet? if not, try introducing fuel to the intake and attempt to start it again, the interlock on the handle works by killing the ignition fire and applying a brake to the flywheel, this should be a Tecumseh engine, carb troubles are quite prevalent on these, by substituting fuel to the intake you are acting as the fuel supply, if it starts and runs briefly you have confirmed a fuel system issue
Jun 01, 2010 | Garden
I have a gas Yard Machine Lawn Mower by Briggs and Stratton. I cannot keep it running and it is loosing oil. What do I need to do?
May be time for a tune up. Replace spark plug, air filter, change oil and sharpen blade. You may have some water in your gas. I would check to see where it is leaking oil. It may be the oil seal on the pto(bottom) side of the engine leaking and needs to be replaced.
Oct 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
MOTOR STARTS, SPUTTERS THEN DIES
Carburetor clogged up, air filter clogged, spark plug fouled; old gas.
This is the best suggestion I can come up with on the information you gave.
Sep 26, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I would push the prime button 3 or 4 times it starts then quiet
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
Apr 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
My mtd tradesman lawn mower does not run smooth. where is the idle mixture adj. screw? the engine is the tecumseh 5.5 hp model #VLV55 501029A(D)
The newer machines do not have a way for you to adjust the Idle, what you can do is change the spark plug or spray some carb cleaner or remove the air filter and run it for a few minutes without the air filter and see what happens
Apr 14, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
1,046 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
