Question about Whirlpool CAP2761K Top Load Washer
Digital coin operated washer stuck on hot water
I try to push the cold and warm flat buttons but the machine only displays and runs with hot water only for initial wash cycle. I flipped over the front access but I was nervous about ruining the electrical circuit board. I thought maybe the area you push down onto the electric tape was maybe stuck. should I try to still access the underside of these flat buttons or possible a bigger problem exists? please help.
SOURCE:
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
jsrock516
  • 5911 Answers
SOURCE: whirlpool front loader washing machine
I would recommend you replace the water inlet valve. This is the only device between the fill hoses and the dispenser that controls the flow of water. The "hissing" noise you hear could be a defective solenoid in the valve that is staying open and allowing water to flow. Try turning the water off at the tap to see if the sound goes away. If it does...water inlet valve. Another tale-tell sign of an inlet valve leaking would be a small trickle of water running down the dispenser tube in the rubber door boot. Over a period of time, the tub will begin to fill and possibly overflow (even with the washer turned off).
You can find a replacement valve at searspartsdirect.com. Just type in your model number and look under the "Dispenser Parts" heading for item number 1 (part #8181694).
Replacing the valve is simple. Just follow these steps:
1. Unplug washer, turn off water supply and remove hoses from the back of the washer.
2. Remove the top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
3. The water inlet valve will be located at the left rear of the washer (as viewed from the front).
4. Remove the dispenser hose, electrical connections and mounting screws and the valve is removed.
5. Install new valve by following these steps in reverse order. NOTE: When reinstalling top panel, make sure you lay panel on top of washer, leaving a couple of inches of room from the front panel. Then, slide panel towards you (front of washer) so that the top panel slides into the mounting clips.
I hope this information is helpful to you. If you still require assistance, or if you feel I'm wrong in my assessment, please post back and let me know.
Posted on Oct 07, 2008
IrishDruid
  • 2712 Answers
SOURCE: Washer will won't run cold water cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    Posted on Oct 12, 2008
    gdmisp
    • 66 Answers
    SOURCE: hot water doesnt work, switch to warm and warm comes out.
    If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
    Posted on Jan 16, 2009
    onthejob5130
    • 640 Answers
    SOURCE: water temperature control not working
    the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
    Posted on Jan 17, 2009
    Cold/cold cyle wash water not cold
    try to do cold cycle first without doing warm cycle first
    Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    My ge front load washer the water constantly runs even when machine shuts off
    Is it HOT! Or is It COLD? Either way your water inlet valves are solenoids. And they get stuck cause they are magnets. So you need to replace both or just the one that feels HOT...Or COLD! The Price is Huge! Hot valves are cheap because they only let in Hot water. It is the COLD one that are expensive for all the Warm, Cool, and 21 other water settings!!!
    If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
    Dec 16, 2013 | Washing Machines
    Asko 6221 washer. push start button and here the click but the washer does not fill. Cleaned coin trap and cleared a dime from one of the lines
    If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Aug 13, 2011 | Asko W6221 Front Load Washer
    I start the machine, it runs till it would appear that it is full of water and ready to start to wash, then shuts off, displaying a message saying "Unable to fill - check water supply" IF you then push the...
    disconnect machine from mains electric supply. remove top cover of machine then check the back of the control panel for a small black pipe, it should be attached to a small nipple in the panel rear if it is not you will get the fault you describe. if the pipe is connected remove it and blow down pipe with your mouth or a foot pump to remove any blockage then reconnect it and try the machine again. check also that the pipe is not trapped or kinked too i hope this helps you
    Oct 14, 2010 | Dyson Memory CRO1 Front Load Washer
    When you start a cycle, a small amount of water will run into the washer and it will sit and do nothing then the pause button flashes. But it will not finish a load even if you continue to hit the pause...
    The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
    If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
    Apr 01, 2009 | GE WBVH6240F Front Load Washer
    No hot wash
    If you shut off cold water the sensor will send message to computerized box the machine will not operate. it shut down the machine.
    Dec 31, 2007 | Bosch Axxis WFL 2060 Front Load Washer
    Whirlpool CAP2761K Top Load Washer Logo
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
