Question about Dryers
Kenmore gas dryer problem need help please
Our kenmore dryer stopped drying hot. The start element would heat up but the gas would not start. I was told the problem was possibly the coil valves in which I replaced today and the the gas finally was lit by the heating element. But, the unit would not draw the fire totally and some of the fire was coming out the pipe in the front. I check the vents and exhaust all clear. Now I notice the sensor on that burner cover is broken or worn out and I will replace that. I checked the blower/suction fan and it works fine. I'm at a loss? Please help. It's a kenmore 1 pc. dryer and washer unit model 417.99175100
  • Pataricia Nolte
    Pataricia Nolte May 11, 2010
    I wonder if the burner assembly has pits and holes and/or if you have the air adjustment on the burner tube assembly set at the proper opening. Yes you should replace the sensor...are you talking about the one with glass on it?
  • 460 Answers
Hope this help U
http://repair2000.com/norun.html
was this helpful?
Posted on May 13, 2009
MODEL PYGT444AWW GAS DRYER LITES UP OK BUT SHUTS DOWN HEAT TO SOON ALONG TIME TO DRY
there is a saftey relay that might be bad and needs replacing.. this is there for keeping dryer from starting a fire or over heateng.. when the dryer start heating the saftey switch is on and once it stops heating the switch is open and and will not dry.. it could be a heating element once it gets hot it expands and will not heat..
Mar 25, 2010 | Dryers
Dryer works but there is no heat in cycles, just plain air drying, do not know how to get hot air, it is an 10 year old kenmore gas dryer, has a dial for time of cycle, can not turn dial to get warm or hot...
I think you will need a repairman to fix this. The gas valve coils may be bad if the igniter radiates but then shuts off before the gas ignites. A repairman can also look at the radiant heat sensor nearby the igniter and replace it if it is bad. He should inspect fuses and circuit breakers and the heating element for continuity, using a device called an OHM Meter. I don't think this is a do it yourself repair job.
Feb 03, 2010 | Kenmore Dryers
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
Dryer want heat up
Hi
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 19, 2009 | Kenmore Dryers
MY KENMORE DRYER WON'T DRY MY CLOTHES
you need to clean out the dryer vent hole and the wall vent hole,that is your problem it's not letting the wet hot air out-mike
Mar 31, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer not drying correctly
The coils are getting hot and won't open the gas valve. replace them dudes
291385a.jpgMore HERE
Mar 07, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas front load dryer.Very little heat, takes 3x to dry
Check your heating elements. check the outside exhaust door is it open.
Feb 20, 2009 | Kenmore 93142 Gas Dryer
Not staying hot-Kemore 80 Series gas
suspect coils bad on burner valve after heating up first time will sometimes fail on following fire ups
Nov 19, 2008 | Kenmore 63942 Dryer
Kenmoore 110.79902890 gas dryer
u may need to check the heating elements inside , or electrical connections to the heating elements
Oct 22, 2008 | Kenmore Dryers
Dryers Logo
91 people viewed this question
Top Dryers Experts
