Question about Garden
Carb adgustment? initsial setings. for a kowasaki fc290v on a lil john deere rider?
  • 246 Answers
Hello raptorboyz:
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 86 Answers
The settings are turn screws in until they seat gently then open them to one and one half turns ,start engine and set to full throttle then adjust high speed needle in until engine runs smooth,then reduce throttle to idle and do the same with the idle screw to get the best idle.
Where was my john deere rw4055e003846 manufactured
John Deere: All riders, lawn tractors, garden tractors, and zero-turns are made at their assembly plants in Greenville, TN and Horicon, WI
May 30, 2015 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
2007 John Deere rider runs for short times but shuts off frequently once blades engaged.
could running out of gas out of gas try rebiulding carb or needs valve job if overheating slowly looses power and stops then has to cool down to restart
Aug 25, 2014 | Garden
John deere d140 ont move
there is a small handle on the back of most riders allowing you to free wheel the machine. If you can push your machine freely now then push the handle in and it should drive
Aug 04, 2014 | John Deere Riding Lawn Mower. D140 48 in....
Are there adjustable drag links for john deere d140 ?
Yes there are. Amazon has them. They are about $26 ea.
JOHN DEERE GY21251 Right Hand Steering Drag Link (Adjustable). Replaces GY20771, Fits LA100 & X100 Series Riders. Replaces NON-Adjustable Drag Links. Replaces: JOHN DEEREGY20771 JOHN DEEREGY21251
The Left and Right are separate products.
Jun 25, 2014 | John Deere 22HP VTwin 48" Riding Mower
My john deere L130 riding lawn tractor has spark and gas going to the carb but wont start. it has new spark plug and fuel filter When starting fluid is sprayed into carb it runs till its burnt up and...
I had a JD 111 rider that may have had the same problem. Turned out to be the fuel line had a weak area and would **** together and not allow the fuel through. It's a cheep place to start.
Good luck!!
Jul 11, 2011 | John Deere Garden
Repair manual for john deere rx85
rx85 johndeere rider turn key to run poisition in neutrual no contac to starter from ign. switch new battery fuse not blown
May 30, 2010 | John Deere Garden
Garden Logo
265 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
