Back to:
Tags:
Whirlpool ED0GTQXMQ Side by Side Refrigerator
FRS26KR4CB1 side by side refrigerator (by 2 users)
posted by mdshuff on Oct 13, 2007
My refrigerators stopped cooling and freezing. I heard a buzzing sound that lasted about ten seconds and would re-occur about every five minutes. The next day I noticed it wasn't cooling or freezing. I replaced the timer/adapter control unit but it still isn' t cooling.
Thanks,
mdshuff
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by maxedison, posted on Feb 17, 2008
I get an intermittent buzz that lasts a few seconds and then stops,now it seems that stuff in my freezer is thawing
Best Solution
posted on Jun 11, 2008
FixYa! (100)
Nasko1304
Rank:Apprentice Apprentice
Rating: 100%, 3 votes
How to replace start relay on Whirlpool Side Ref.?Insrtuction sheet Please!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on FRS26KR4CB1 side by side refrigerator:
I don't want to Accept this solution
Solution #2
posted on Oct 15, 2007
Not Rated (0)
piranha
Rank:Guru Guru
Rating: 87%, 82 votes
It sounds as if you have a defective compressor start relay.  It is located on the side of the compressor, usually contained within a black plastic housing (box).  If ordered, it will most likely come with an overload proctector.  Change both parts.
Thank You!
Can you Help with these Refrigerators problems?
Whirlpool ED0GTQXMQ Side by Side...
There is a click sound when the lever is depressed but no...
When you press the dispenser lever there is no sound and...
Our freezer door on this side-bt-side did not close...
the airflow from the freezer is not strong enough...
whirlpool model ED22DW will not stop making ice. Ice is...
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
