Question about Silver Jeans TVR Tuscan Wireless Street Mouse
Automatic headlights 2002 s10
How can you shut off the lights so they dont come on every time you turn the car on and you have to manually turn them on and drive with them?
    New Friend:
How Mach 2002 modie
Posted on May 02, 2015
    Problem Solver:
What other s10 modles have a 3 inc suspencen lift on the body and can i put it on my 2002 s10 crew cab 4wheel drive?
Posted on May 12, 2009
Headlights will not shut off when key is off 2000 S10 lights stay on and drain battery Is this the head light switch?
Are you talking about headlights on as daytime running lights, or on automatically at night? Different modules are involved depending on which case.
Jan 01, 2017 | 2000 Chevrolet S-10
Why don't automatic headlights work?
On my car, a Renault, the automatic lights can be deactivated using a setting in the menu. Maybe yours can as well. Have a look in the manual or online. Maybe ask at a Chevvy dealers.
Feb 04, 2016 | Chevrolet 2002 Chevrolet Silverado 1500...
I replaced the tumber and key in my 2002 s10 le 4x4 with one from a 2002 s10 2wd,im 4x4 has a 4.3L and automatic,while the 2wd is a 2.2L and a standard,now it wont start
if you replaced the ignition cylinder housing as well the passlock system will have to be relearned. Hook some sort of battery charger or stabilizer. attempt to start the vehicle and just release the key to the running position....check security/theft light on or flashing. after about 10 minutes the security/theft light should go off, turn key off but dont remove for 5 seconds, then attempt to start again. Do this 3 times for a total of roughly 30 minutes and it should start.
Oct 16, 2013 | Chevrolet Monte Carlo Cars & Trucks
Ok to further clarify my problem. When you start the car, the headlights, tail lights, and dash lights stay on. Brake lights work normally. When you shut the car off, the lights shut off properly. If you...
most all newer vechicle when turn off ignition.light will turn off automatically.only time use manual headlight switch when malfunction in the automatic lights not turning on manual light design just get you home.
Sep 21, 2013 | 2001 Pontiac Grand Prix
Head light problems sometimes they will not shut off sometimes they (low beams) come on by themself high beam will not shut off
Are you sure there not running in daytime running light, when you think high beams are on
Also, there is sensor on the dash, usally on the speaker grate, that senses night and day. In the daytime your headlights will automatically come on when your car is in drive, and be on the high beam bulb, but dimmer than regular. At night, or in low light conditions, your lights will automatically switch from daytime lights to regular low beams. And yes, even when your switch on the dashis turned off, your lights work automatically.
To turn of the auto setting, just push the override button for your dome light, in and out 3 times, you should hear a chime, and your lights should shut off. This setting resets everytime you shut your vehicle off. Or to turn the auto setting back on, push the over ride button 3 more times.
Apr 15, 2011 | 2002 Chevrolet TrailBlazer
My automatic headlights sometimes will come on by themselves when they're supposed to but most the time they don't. When they do however, they will only work for a couple days at a time and then, without...
you have day time running lights you are supposed to manualy turn them on at night. if you dont manually turn them on,on most cars the tail lights are not illuminated the automatic headlamps only turn the head lamps on. and they are controlled by the sensor located in the middle of your dash board
Jan 11, 2010 | 1992 Lincoln Town Car
Headlights come on automatic but will not shut off
must of this vehicles with automatic headlight systems, lights will shut down or turns off after few minutes giving driver time to walk to a secure place, is it possible lights won't turn off at all, you must have problem with headlamp delay system
Nov 19, 2009 | 1993 Lincoln Town Car
2002 Saturn SL headlights stay on
On a 2002 saturn, the headlights are not automatic, you have to turn the knob on the end of the signal light lever to turn them off.
Also, some models are equipped with "Daytime running lights"; a safety feature. these daytime running lights are just the amber colored front signal lights, which turn on automatically when the parking brake is released to make your car more visible during daylight hours. Furthermore, if any headlight refuses to shut off, there is an electrical problem, most likely a failed relay, which are located in the underhood fuse panel and can be checked quite easily with a multimeter, relay failures are veryrare, but not unheard of, especially in vehicles equipped with aftermarket fog lights. Thankfully they are cheap and readily available and are as easy to change as a fuse.
Dec 19, 2008 | 2002 Saturn Sl
!997 Chevrolet S10 headlight problem
ya know it kinda sounds like the headlight switch that switches from high beam to low beam has a bad contact. You don't have one of those 4-beam modules that turn on all 4 lights on high beam do you? that thing screwed my whole headlight system up, I ended up throwing it in the trash.
I have the chiltons and haynes manual, I'm sure between the two we'll find a good diagram. I gotta get my youngin to open house at school, but I'll pull the books out and send you the wiring diagram.
Aug 07, 2008 | 1997 Chevrolet S-10 Pickup
Silver Jeans TVR Tuscan Wireless Street Mouse Logo
386 people viewed this question
Top Silver Jeans Computers & Internet Experts
Alun Cox
mxguy1000
Level 1 Expert
Willie Mondo
Willie Mondo
Are you a Silver Jeans Computer and Internet Expert? Answer questions, earn points and help others
