Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
The pull to start rope is stuck, will not retract
  • adlentz May 16, 2009
    same problem.. pulled rope and now it won't retract
2 Suggested Answers
  • 11 Answers
SOURCE: starter rope will not retract
Either you have a broken rewind spring, or the starter mechanism is dirty to the point where the force of the recoil spring is not sufficient to pull the rope back in.
WEAR SAFETY GLASSES while disassembling your starter mechanism to see what the problem is. Upon reassembly, it is a good idea to lube the post in the starter housing (the one the pulley slides over) with some graphite or teflon lube.
Posted on Oct 25, 2009
Rope was stuck, replaced starter spring and reassembled it now pulls out but does not retract.
check spring is inserted correct and or was it pre wound so that it retracted
May 03, 2018 | Garden
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
Rope will not retract.
I am assuming you tried to pull start and the rope is stuck out. Just try pulling the rope while it is out, but stand on the hedge trimmer. Sometimes when this happens to me, I just pull the rope a little extra and then hang onto it when it goes back in. Alot of times, I think the rope gets caught on the outside of the retraction pulley causing a tangle.
Aug 05, 2010 | Poulan Ght225 25cc Gas Hedge Trimmer
Weedeater gas blower FLI500E. The pull cord has become jammed. How can I un-jam the rope pull? I have removed the bottom of the blower and can get the rope pulled out, but it will not retract properly or...
You have to find a way to push the starter. It normally gets all stuck due to grease. One push with a screwdriver on the actual starter (The thing the rope turns) should wind the whole cord up. If not, clean it. Alot of oil/chunky-ness gets trapt when your using it.
Apr 27, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
Starting rope won't rewind
There are two or three screws that hold the retract assembly on to the engine cover. Take these off, and pull the retract off. First, try to turn the pulley on the inside in the direction that the rope would turn it if you you were pulling it out. Will it rewind? If not, there is a screw on the top of this assembly, that's covered up with a sticker. you'll need to remove this screw, and pull the pulley out. There will be a spring on the inside of this. check the spring to see if it's broken. If not, and it's just come loose, put it back into the slot that holds it, and wind it up enough to get it back together. turn the spring in the direction that the rope would pull it out, until it won't go any more. Hold it, and reinsert the rope, tie a couple of good knots in the end, trim the excess, and let it retract the rope into the assembly. Put the assembly back on your engine, and you're good to go.
Feb 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Starter rope will not retract
Oct 25, 2009 | Troy -Bilt String Trimmer/Blower...
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
We have a briggs and stratton sovereign petrol mower the pull cord has gone loose no give so unable to start mower
If I'm understanding you correctly, the pull chord is out and will not retract so you can pull again?
If this is so, I'm thinking that there may be some obstruction keeping your spring from returning the rope. The spring is wound like a clock spring. When you pull the rope, the spring wants to bring it back. Sometimes a twig or dirt or other type of abnormality might prevent the spring from retracting your pull rope.
You might need to loosen the engine cover to remove the obstruction.
Jun 27, 2009 | Garden
Pull-cord will not retract.
If you put a longer cord on it , then it will not retract as far and get stuck.
Jan 24, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
454 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
