Question about Garden
I have a ford yt 125-G I bought from a neighbor and I got it running and when I let out on the clutch, it kills the motor.
  • 86 Answers
Check out to see if the blades are turned off seat saftey switch,sounds like a saftey switch problem.
Posted on May 12, 2009
Not starting off starter but goes with a push
Hi, Malcom Smith famous dirt bike rider extraordinaire and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a "LOAD" test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
APRILIA RS 125
Aprilia rs 125 trouble starting arghhh
RS50 wont start off motor but will easy when bumped
https://www.manualslib.com/manual/363586/Aprilia-Rs-125-Tuono-2003.html
Products at Aprilia Genuine Parts Aprilia Parts Aprilia Spare Parts...
APRILIA RS 125 2006 Manual
Mar 18, 2017 | 2003 Aprilia RS 125
2002 yz 125 when I put it in gear it will shut off acts like the clutch is not working when I adjust it on the handle bars it slips
Mechanical issue: clutch not disengaging completely...
engine off - put in gear and roll back and forth with clutch released does engine stop the bike from rolling? Now pull clutch lever in and try rolling again is clutch cable adjusted properly?
Electrical issue: bike thinks clutch is still engaged and kills motor when not in neutral
Is the clutch switch properly connected and working? Is it adjusted properly? Use a multimeter to read resistance across switch contacts does it change state when clutch is pulled in?
Jul 28, 2014 | Motorcycles
How to replace 2003 Yamaha TT-R 125 clutch
Hi, Scott for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
TTR 125 Clutch Replacement Question TTR
2001 Yamaha TTR 125 Clutch Removal
http://www.yamaha-motor.com/assets/service/manuals/2007/LIT-11626-20-01_ttr125all_1961.pdf
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2012/2012_ttr125le_lit-11626-25-32_2021.pdf
Jul 09, 2014 | 2003 Yamaha TT-R 125
2001 yamaha yz 125 motor seized
If the clutch drags you need to check the plates and the worse thing to do when a bike wont crank is to pop start it you just do more damage and defiantly only use the right oil
Nov 22, 2012 | Yamaha Motorcycles
Motor dies
it sounds like your safety switch under seat is faulty check & replace if needed
Jun 25, 2010 | Craftsman YT 4000 42" Briggs Stratton 24...
I have a 2001 kawasaki 125 eliminator shuts off
If it dies when put into gear then its the side-stand switch (stand is down or switch not working)
If it dies when the clutch lever is released then either it was released too quickly with not enough revs, the engine doesnt have enough power to pull away or possibly the clutch switch is working in reverse
Good Luck
Hope this helps.
(If it does then please mark this as 'useful')
Ride Safe
Bike-Doc
Jan 29, 2010 | 2007 kawasaki Eliminator 125
I have a yz 125 with a rebuilt motor i put the nuw motor
A very common problem with wet clutches is that many folks do not use the correct oil. The plates in the clutch are sandwiched under spring pressure and there is nothing in the mechanism to release them, so if the oil creates too much "stiction" then the plates can become suctioned together.
I suggest first trying an oil change using an oil designed for use with wet clutches. Then, get a running start, hop on the bike and drop it into gear. Then pull in the clutch and while holding the clutch lever in, rev the motor to break the plates loose. If this fails after a few attempts, your plates could be rusted together - possibly from a leaking waterpump seal or a ride through deep water. A simple tear-down of the clutch will tell the tale and this can be done without buying any parts if you are careful.
Nov 08, 2009 | 2003 Yamaha YZ 125
Kill switch wires DT125
could be black or green,but if it is disconected it sdhould run as the switch just earths the power
Jul 26, 2009 | 2006 Yamaha DT 125 X
Kx 125 2003
im pretty sure that the bike is a all in one menin that oil in tranny is same that flows in motor
Jul 22, 2009 | 2003 kawasaki KX 125
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
