Printer shows ready, whenI send a print job to the printers it displays printing, but does not print. The unable to cancel or remove printing jobs.
    Problem Solver:
  • 7 Answers
Does this printer have a print button on the printer itself?
If so, press it to see if it will print a test page from the printer itself.
If it prints, then you have a loose connection to your printer. Unplug and replug that.
Then cancel all documents by double clicking the "printer" in the start menu. This should bring up the menu to click on printer then pause or cancel the print jobs. See if the pause print jobs is also selected. Unselect if it is.
Next, do you have the install disc for this printer?
If you do, then uninstall the printer using control panel, add/remove programs, and then reinstall the printer following the install wizard on the original disc
Posted on May 12, 2009
  • 4 Answers
This problem tends to occur, when the "Print Spooler Service" have either stop, became corrupt in its run-time profile, or something completely messed in the windows kernel itself.
type. services.msc in the command prompt.
right click the "Print Spooler" and stop the service.
then log-off the windows profile, or restart the machine, and it should start automatically.
If the print jobs are still in queue, try deleting them again.
That should work
Posted on May 11, 2009
  • 3,267 Answers
Check if the printhead starts moving when powering on the printer. The problem might lie in the printhead electrical contact pints in which case clean it gently. Alternatively replace the print cartridge where at least black ink is present. If these are OK but it wont pull in the paper then the rollers might be jammed. If its a laser printer,check by changing the tober cartridge amd post the result as a comment.........sodeep
How to fix error print unable ob brother l2540dw
Most print unable or unable to print are either due to a corrupt print job or a size not compatible with your printer. If you are using Windows OS, go to your "Printers and Devices" option and left click on the printer icon for the model your using. you will see a bar that will expand to include the phase "see what's printing". Click on that option and it will show you all jobs pending and if there is an error message with that job. Click on that job, then click on "Document" go to "Cancel" to remove that specific job.
Sep 18, 2017 | Brother Office Equipment & Supplies
Not showing ready on the display
To help you troubleshoot the issue, please follow the steps given below:
- Make sure the printer top cover or printer door is closed properly.
- Make sure printer power connections are turned ON.
- Make sure there is no print job stuck in queue, if yes then you need to cancel all the print job from queue and check printer shows ready to print display.
If issue persists, please update the printer driver from your printer manufacturer website.
GuruAid.com
May 31, 2016 | Office Equipment & Supplies
Cancel print job with a linux operating system
HI,
You've sent a print job to your printer and the green light is blinking, but the printer is not printing. The light blinks for a very long time.
The blinking light indicates that the printer is recieving your print request and will print shortly. If the document you are attempting to print is very large or contains many graphics or images, the printer must spool this data into its memory before printing. This can take quite a bit longer than usual. PDF files are notorious for taking longer than other document types.
In this case, it is best to wait a period of time before taking action. Give the printer 10 minutes and see if it prints.
If it does not print within this window of time, do the following.
1. In the bottom right corner of your screen, you will see a small printer icon. Double click on this icon to open the printer job menu.
2. You will see your print job located there, with other information, including its status.
3. Select the job by right clicking on it and select Cancel.
4. The job should cancel itself.
5. Unplug the printer, removing all power and leave it sit for a couple of minutes.
6. Plug the printer back in and allow it to go through its start up phase until the "Ready" indicator light is solid. This indicates that the printer is ready to recieve jobs.
7. You may now attempt to print again.
Thanks,
HP Printer Support
Jul 16, 2014 | HP Office Equipment & Supplies
Printer blinking red and showing letter E
Error description:
The Attention (red) light is blinking. There are six possible causes that will display the Attention light pattern:
-Paper out
-Door open
-Print cartridge missing
-Paper jam
-Paper sensor jammed
-Duplexer error
Solution :
After the cause of the problem has been addressed, pressing GO will cause the printer to attempt to recover from the cause of the error. If the printer is unsuccessful, it will continue to display the Attention message until the cause is remedied.
Pressing JOB CANCEL will cancel the print job and the printer will return to the Ready state (Ready light on) unless there is a paper jam still in the printer or the print cartridge is not in the printer.
For more details visit the link below :
Resolve Printer issue
Jun 09, 2011 | HP DeskJet F380 All-In-One Printer
Unable to delete pending jobs
To cancel one or more print jobs, follow these steps.
1. Go to Control panel - Printers .
2. Right-click the icon for your printer, and then click
Open.
3. To cancel individual print jobs, right-click the print job
that you want to cancel, and then click Cancel.
4. To cancel all print jobs, click Cancel All Documents on
the Printer menu.
Alternatively if this doesnt work you have to restart the spooler service
1.Go to Control Panel - Click Administrative Tools.
2.Double-click Services.
3. Stop the service called Print Spooler.
4. Click Start to restart the Print Spooler. Then click OK.
Hope this helps.
Mar 12, 2010 | HP LaserJet P4015N Printer
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
Bloom laser 1600 printer problem:
i wanted to cancell a print job and i cancelled a print job by selecting and cancelling. Under status it shows deleting P.
but actually it is not deleted. without deleting this i am unable to
print the second job. How to solve this?
Dec 05, 2009 | Office Equipment & Supplies
Unable to cancel print queue
You can cancel a print job from within Windows by going to Control Panel -> Printers and double-clicking on the appropriate printer. Right-click the print job you want to cancel and select Cancel from the context menu. Anything already sent to the printer will continue to print.
You can also cancel a print job from the printer by pressing Cancel on the control panel. This applies to whatever is currently printing.
(You may want to remove any paper from the paper tray first.)
Clicking the cancel print icon stops the job from continuing to spool, but whatever is still in the printer's memory will continue to print until exhaused or the job is cancelled from the printer's control panel.
Apr 14, 2009 | Office Equipment & Supplies
HP4000 not printing LPT1
Dear sir;I believe you can try " cold reset", that's means going to clear all data from the printer memory and sets all the defaults back to the factory settings.performing a "cold reset" resets the jetDireect configuraion. to avoid making changes to yourconfiguration, remove the jetDirect card before performing a cold reset. if possible, print a configuration page prior to performing a cold reset. this will document current settings for later reference.
to perform a cold reset;
1, turn off the printer.
2, while pressing "go", turn the printer on. COLD RESET appears briefly on the display, then INITIALIZING appears.after a few seconds, RESTORING FACTORY SETTING appears on the display, followed by OFFLINE.the cold reset is complete.
3, press "go" to return the printer online "ready " appearson the display.
Little bit complicated but is easy ,hope can take care your problem, GOOD LUCK! Let me know the resolve please!
HAVE A HAPPY HOLIDAY !!!
Dec 15, 2008 | HP LaserJet 4000 Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
