Question about Pioneer DEH-30MP CD Player
Pioneer deh-40mp My remote wire has come out from directly behind the head unit now Im not sure which hole it came from and cannot find any wiring pics to remedy my problem.
Well there is easy to find installation manual and find out for sure... :)
if my memory is good, upper hole is for aux and other beneath - remote...
Posted on Oct 15, 2008
SOURCE:
Which wire is the remote wire for the pioneer deh-p6900ub head unit
if ;you are talking about the amp remote wire it is blue/white.
Nov 10, 2010 | Pioneer DEH-P6900UB CD Player
I am putting an external amp to run my subs and i need to know where to hook my remote wire to from the back of the deck
Norrmally the head unit/deck has a blue wire for the remote in the Pioneer set. So check this out and use a meter to see for voltage when the head set is switched on. Now you can connecct this as the remote swiching required for your amplifier. hope you look into the back side of the head unit ,in the cluster wire from the connectors. Good day
Aug 15, 2010 | Pioneer DEH-1500 CD Player
Where do i hook my remote wire that goes to my amp?
The remotte wires from the head unit should go to the amplifier. Look for the main power inthe amp which is connected directly through a fuse to the batterry and the remote connection must go to the rremote of the head unit. Usually this is blue wire in older models but in newerr ones it is marked on the connector screw pad. connecct this and on poweering your headd unit the amp must come on. Now the connection is correct. connect your speakers and switch on. Hope you got this right . Good day
Where do I plug in my REM wire from my amp to my
on the back of your head unit is the remote arial wire. this is the one you connect to the rem on your amp
Apr 05, 2010 | Pioneer DEH-P80MP CD Player
Pioneer DEH-P2950 Where do I connect the remote wire from my unit to my amplifier
where it says remote on the amp not on the grounded area of the amp u migth blow your unit out
Oct 06, 2009 | Pioneer DEH-P2900MP CD Receiver...
Pioneer head unit plays in accesory mode, but not when vehicle is fully started
he tapped into starter wire instead of accessory. Remove radio and verify the switched power (red) wire is properly hooked up to an accessory wire that stays on after vehicle is started.
I believe the wire is white/black behind the radio. Check with a voltmeter to be sure.
http://www.the12volt.com/installbay/stereodetail/967.html
for the wire codes to that vehicle.
Oct 18, 2008 | Pioneer DEH-P3700MP CD Player
Pioneer deh 1600 has no power
Well.. if there is smoke coming from the head unit, the head unit could be bad. It odviously may have a wire crossed or a fuse blown, or even the wire harness could be bad. First, check the fuse for the radio on drivers side door, then check the other fuse box under the hood. Make sure all radio fuses are intact and not blown. Second, check behind the head unit to make sure no wires are touching each other and shorting out. Third, if nothing else helps, buy a new head unit & wiring harness :]
hope this helps!!!
Jun 12, 2008 | Pioneer DEH-1600 CD Player
Wire Color Code
what color is what on the pioneer deh-p4100
Jul 12, 2007 | Pioneer DEH-P4100
Pioneer DEH-30MP CD Player Logo
264 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
