Question about Maytag Dryers
Drum belt tension
I replaced the idler pulley and pulley arm. I must have put something in the wrong place because there is no drum belt tension. It's a Maytag Dryer model # SDG2606AWW.
I found a dryer manual on the web that showed how the drum belt wrapped around the pulleys.
Problem solved.
Posted on May 12, 2009
Replace belt whirlpool dryer WED7500VW
remove the front panel on the dryer, get the old belt and take it and the model number into your local shop to get the proper belt, put the new belt around the drum with the groves towards the drum, replace the front panel. on the lower part section of the dryer on the back there will be a panel you remove it see the motor, reach in and place the belt around the pulley on the motor then carefully force the tension idler down towards the floor till you can place the lower section of the belt into the pulley on the tension idler and release the idler. you can now run the dryer, as the drum turns the belt will place itself. hope this helps.
Oct 16, 2016 | Whirlpool Dryers
Dryer belt is loose, how to adjust tension in idler arm?
It sounds like you didn't install the belt onto the idler pulley in the correct S-shape. The idler pulley should always keep the belt tight under spring tension (no adjustment screws).
Here is a video, and tho it is a completely different model, almost all dryer belts/pulleys are installed in this manner. You can skip to the 2:30 to 2:45 time frames, where it then shows exactly how to re-install the belt on the idler pulley.
Nov 02, 2014 | Frigidaire FGX831FS Washer/Dryer Laundry...
How to fit a belt to a hotpoint v3d01 dryer
Instructions
Tools Needed:
Screwdriver
Hand vacuum
1. Unplug the electrical cord of the Hotpoint tumble dryer from the electrical outlet before attempting to replace the belt.
2. Pull the door open on the dryer and locate the screws on the underside of the top cover. Unfastening the screws with a screwdriver.
3. Flip the top cover back so that it rests on the rear hinges, and find the screws on the top of the front panel on the inside of the dryer cabinet.
4. Undo the screws on the top of the front panel with a screwdriver, and tilt the panel away from the dryer cabinet. Unplug the door switch connector from the metal prongs on the back of the front panel.
5. Lift the front panel up and remove it from the dryer cabinet. Set it out of the way. Locate the idler arm and motor on the bottom of the cabinet.
6. Move the idler arm forward to relieve the tension on the belt, and take the belt off the idler arm and motor pulley as well as from around the drum.
7. Place the new belt around the drum, looping it over the idler arm pulley and around the motor pulley. Move the idler arm back into place to add tension to the belt.
8. Verify that the belt is lined up correctly with no twists in it, and put the front panel back on the dryer cabinet. Plug the door switch connector into the metal prong on the back of the panel by hand.
9. Secure the front panel with the screws at the top, and flip the top cover down over the cabinet. Secure the top with the screws on the underside of the front lip.
Feb 23, 2011 | Dryers
My dryer starts to squek real loud when it is running
The source of this noise is usualy the dryer drum drive belt.
  • Unplug the electrical cord before replacing the dryer belt.
  • 2
    Pull open the dryer door and locate the screws underneath the top lip that secure the top of the dryer.
  • 3
    Unfasten the screws holding the top on with a screwdriver and lift the top, flipping it back and resting it on the hinges.
  • 4
    Unfasten the holding the front panel on the cabinet, using a screwdriver. These screws are at the top on the inside of the panel.
  • 5
    Disconnect the door switch wires on the back of the front panel by hand, pulling the connector straight out off the electrical prongs and setting the front panel aside.
  • 6
    Locate the idler arm pulley next to the motor on the bottom of the cabinet near the back and push the idler arm forward to relieve the tension on the old belt.
  • 7
    Remove the old belt from around the idler and motor pulleys as well as from around the dryer drum and take the belt out of the dryer cabinet.
  • 8
    Place the new dryer belt around the drum in the center of the cabinet, fitting the belt inside the V-groove in the center of the drum, and lay the rest of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
  • 9
    Move the idler arm forward to allow room for the belt and thread the end of the new belt around the idler arm pulley and over the motor pulley, letting the idler arm move back to apply tension to the new belt. Check the new belt over to verify that it is lined up correctly in the V-groove on the drum and around the pulleys and that there are no twists in the belt.
  • 10
    Place the front panel back on the dryer cabinet, securing it with the screws on the top of the panel with a screwdriver, and plug the door switch wires back into the electrical prongs, pressing the switch wires on by hand on the back of the front panel.
  • 11
    Lower the top of the dryer back down onto the cabinet and secure it with the screws underneath the lip of the front panel.
  • 12
    Plug the electrical cord of the Hotpoint dryer into the electrical outlet.
  • Dec 28, 2010 | Hotpoint Dryers
    Belt does not go back on with enough tension.
    Are you replacing a broken belt? If so then the belt should go flat side of belt in toward drum. Make sure the belt is not in the slight channel in drum put belt from right under guide around idler then insert loop under idler and attach loop to motor. Should end with ribbed side of belt on pulley.
    Nov 20, 2010 | Maytag Dryer Idler Pulley for Large...
    How do you replace the belt on a Maytag clothes dryer
    frist unplug dryer then take front panel off dry then take lint housing off there 4 screw on both side take that off remove broken belt put new belt on around dryer drum an loop belt over white idler pulley an around motor pulley idler pulley put tension on the belt
    Apr 24, 2010 | Dryers
    How to reinstall Idler Pulley and belt for kenmore Dryer Model 110.66112501
    First, assuming you have the drum out, there are two slots on the bottom plate of the dryer, hook the end of the idler pulley into the left slot with the angle as you look at it up and to the left. as you set the pulley in place the second slot will match the prongs of the idler pulley. With the idler in place, now put your belt around the drum (you should see a polished spot where the original belt rode and wore off the paint). Then use the belt to help guide the drum install. Set the drum on the rollers in back, keeping the drum level to the dryer. It helps if the whole dryer is tipped back against a wall at about a 45 degree angle to get the drum in place, but that makes your aligning the belt a pain at the same time. I suggest have the dryer at an angle to put the drum in then place it level to align the belt.
    You'll need to use both hands to get the belt in place. First thread the belt under the idler pulley wheel in the opening under it. Next you'll need to push the idler wheel as far up and to the right as you can to get the tension all the way off as you hook the belt around the motor. Once on the motor, slowly let the idler down into place.
    If everything is aligned correctly it will work just fine. Just make sure when you put the bulkhead in again that the drum rides on top of the slider pads and that the drum rotates freely with only the motor tension on it. 839edf2.jpge839dbf.jpg
    Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
    Install dyer belt MAYTAG
    Hello there
    Here is a detailed instruction for you ok
    1. Remove the two screws that hold the control console to the dryer; they are located on each end of the console. Turn the control console forward onto its face. Disconnect the wiring harness from the dryer to the console. Press in on the locking tab and pull the connectors apart. Set the control panel out of your work area. To remove the top, insert a putty knife between the front and top panels. Locate the retaining clip and push in on it to release the corner of the top panel. Lift up on the corner and release the opposite retaining clip. Set the top panel out of the way. Two screws that attach the front panel to the sides are located at the top corners. Remove the screws and swing the top of the front panel out so that you can access the door switch wiring harness. Disconnect the wiring harness from the door switch and lift the front panel away from the dryer.
    2. Replace the Belt
    3. Locate the idler pulley by reaching behind the drum and motor assembly. Using your hand, push the idler pulley to the left to release tension on the belt2.gif. Notice the routing of the belt around the motor and idler arm for reference when attaching the new belt. Remove the belt from the motor pulley. Lift up on the drum slightly and remove the belt from the drum.
      With the rib side pointed inward, lift the drum up and set the belt around the drum. Route the belt through the motor pulley and idler pulley. Pull the idler pulley to the right to reapply tension to the belt. ok?
    4. not too hard
    5. hope this is verry helpful for you
    6. Best regards MIke
    Oct 15, 2009 | Maytag PYE4500AY Gas Dryer
    I replaced the idler pulley and pulley arm on my Maytag Dryer model#SDG2606AWW, and now I don't have enough tension for the drum to turn.
    http://www.pcappliancerepair.com/model-display.php This site shows your belt going around the motor a half turn, grooves to the pulley. Then you have to wind up the spring-pulley and put the belt over the roller a half turn. That should take up the slack. The packaging of a new belt should show how it goes.
    May 12, 2009 | Maytag Dryers
    Idler pulley arm
    there is a certain way that the belt is supposed to loop around the tensioner and motor. this picture might help.b00f604.jpg
    Jul 19, 2008 | GE DBSR453EBWW Electric Dryer
    Dryers Logo
    228 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
