Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
My 61 inch RCA HDTV shows a redish shadow outlining each object
My television is showing a picture that appears bowed in the center and each object has a redish shadow outlining it.
  • RCA Master
  • 3,459 Answers
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing thMy 61 inch RCA HDTV shows a redish shadow outlinin - 47a7bc4.pngf it fails to fix the convergence your need to fix it. See below for a fix
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
Its a 2004 61 inch big screen projection tv and the subject on screen has three colors outlining it green red blue on the outer portion of subject on screen
Tv have a problems known as a convergence pictures problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to repair it.To solved tv pictures convergence problems.The shop will cost u like $300-350 for parts and labors.
Jul 05, 2011 | RCA R61WH76 61" HDTV
Picture shows double
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 03, 2011 | RCA HD52W59 HDTV Projection Television
RCA R61WH76 61 in. HDTV Television Red green line top screen
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 23, 2011 | RCA R61WH76 61" HDTV
My 52 inch rca hdtv comes on but it looks like the screen is bowed and the colour is off.do you know of any solutions to this problem.
My rca 52 inch hdtv picture looks bowed on the top and bottom of screen. And everything looks like it has a red shadow behind it.
May 12, 2010 | Televison & Video
Have TV RCA HDTV model R52WH74 and three colors are appear behind object[blue,red and green some thing like that]now i need to know is it some part go bad and need to be replaced [which part is?]or do i...
You can get the ITC222 and ITC222A convergence option missing repair kit at the following link. www.tvrepairworld.com the kit is listed under the RCA repair kits and it has the parts plus CD which shows how to do the repair.
Sep 10, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
Green shadows around small red objects (football players with red shirts)
turn tv of by power point for 1 hour then switch back on that resets the picture if still happens may need a service
Jan 27, 2009 | RCA HD61LPW164 61" Rear Projection HDTV
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 46F500
Having yellow and blue shadows outlines show up on picture.
Oct 03, 2008 | Hitachi 46F500 46" Rear Projection...
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
216 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
