Question about Vehicle Parts & Accessories
Disarm car alarm
Transmitter got lost, the alarm is on...how do I disarm a ''Crimestopper Security Products'' alarm, model # 9601 CJ - I have the manual, but it's useless, I phoned the company and left msg. never got answer. I want to get rid of this old alarm. How do I disconnect it...please help.
Thank you.
  • 91 Answers
First off ill assume the alarm goes off and oviously you have no remote. first disconnect the negative ground (black wire on your battery) so you can work with out the alarm going off.
the "brain" of the alarm should be located on the drivers side underneath the dash, go underneath and look for a small black box zip tied into place with wirescoming into it that looks like it shouldnt be there. it should have crimestoppers inscribbed into it.
there will be wires clipped into the brain, disconnect these and your alarm is deactivated.
to remove, trace wires to where they tie in, cut off wire that leads to brain leaving origonal facory vehicle wire there, and tape over cause you dont want anything to ground out. once you have done this, reconnect the negative, and your good to go
Posted on May 11, 2009
  • 3,267 Answers
Simply disconnect the power leads to the alarm...........sodeep
How do you turn off an alarm for a 2005 Saturn Ion
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the CTD armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the BCM stores the CTD mode status in memory.
To disarm the CTD system in arm pending mode, SECURITY indicator flashing and doors open, perform 1 of the following:
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
Jun 24, 2016 | 2005 Saturn ION
What is the process to reset the theft system on a 04 Cadillac SRX
Disarming the System To disarm the system, either unlock the doors using the transmitter, or start the vehicle with a recognized transmitter in the vehicle. To avoid setting off the alarm by accident: . Lock the vehicle with the transmitter after all occupants have left the vehicle and all doors are closed. . Always unlock a door with the transmitter. Unlocking a door any other way will not disarm the alarm. If you set off the alarm by accident, turn off the alarm by pressing the unlock button on the transmitter. The alarm will not stop if you try to unlock a door any other way http://www.cadillac.com/content/dam/Cadillac/Global/master/nscwebsite/en/home/Owners/Manuals_and_Videos/01_images/2010_cadillac_srx_owners_manual.pdf
Mar 13, 2015 | Cadillac Cars & Trucks
How do I turn off the alarm on my 2002 jeep wrangler tj?
is this just alarm , and or the immoblizer SKIM problems, why not post the symptoms, or if opr guide missing.
all answers USA spec cars......
all answers STOCK cars, not hacked or with non Jeep parts.
the SKIM can not be defeated.
if still stock is it? with stock alarm. is it?
the fsm is free for 02 TJ
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
it explains all there. (no chapter on alarm only the IMMO )
chapter 8Q
theft and security chapter.
I attempt to guess your question, how to disable just the door alarms. (not SKIM)
my 02 TJ has no such thing, door alarms at all , mine had rag windows
and and no electric door locks at all, just a key. (mech lock)
not only that, the 02 operators guide has not a word at all about any alarm. period (USA cars)
my 08 JK however has doors with glass windows and all trimmings.
the alarm on my 08 is disabled by these steps.
To Disarm the System
To disarm the system, you will need to press the UNLOCK
button on the RKE transmitter, or turn the ignition
key to the ON position. If something has triggered the
system in your absence, the horn will sound three times
when you unlock the doors. Check the vehicle for tampering.
The Security Alarm System is designed to protect your
vehicle; however, you can create conditions where the
system will arm unexpectedly. If you remain in the
vehicle and lock the doors with the RKE transmitter, once
the system is armed (after 16 seconds), when you pull the
door handle to exit, the alarm will sound. If this occurs,
press the UNLOCK button on the RKE transmitter to
disarm the system. You may also accidentally disarm the
system by unlocking the driver's door with the key and
then locking it. The door will be locked but the Security
Alarm will not arm.
next time post symptoms, so we can be on the same page..
Mar 08, 2015 | Jeep Cars & Trucks
I have a crime stoppers remote start/alarm when I use the unlock button it only unlocks the doors, it does not disarm the alarm. How do I disarm the alarm?
You need to hook up the disarm wire also and depend of what car you're working on, it will disarm when you unlock the car.
Jan 13, 2011 | 2-Way Remote Starter
When use remote starter to start car, factory alarm goes off. How can I use the remote starter without this happening?
It sounds as if your vehicle's factory alarm is not disarming before the remote start sequence. You will have to disarm the factory alarm before start. On most vehicles there is a disarm wire, usually in the door that operates with the key cylinder. To test, probe the wire at the key cylinder while unlocking the door with the key. Some vehicles have the disarm wire in the driver's kick panel, but they operate the same way (with the key cylinder). Other vehicles can be disarmed with pulsing the key sense wire. Some vehicles do not have a factory alarm disarm wire,i.e. some Subaru and GM cars and trucks. They can only be disarmed through data modules. More information on the year/make/model of your vehicle will be needed to accurately solve your problem.
Nov 08, 2010 | Prestige Remote Start
How can i disarm the factory security alarm.i have tried the key locks. i have no remote with the car. i didnt know it had an alarm when i bought it . 1995 chrysler cirrus
Here is what I do on my 95 Cirrus I also do not have a keyless remote (well I do but is broke) and after frustation after frustation trying to disarm the factory alarm I find out that by unlocking the passenger front door with the ignition key from the outside will disarm it you may have to try few times before it's disarmed you need to make sure that the blinking red light stops blinking and all of the locks on all 4 door are up or unlocked, this is what I been doing for 3 years now and that's how I disarm the alarm on my car, I hope this helps.
May 15, 2010 | 1995 Chrysler Cirrus
The alarm went off and now the car won't start
You must disarm the alarm to be able to start the car. Either with the transmitter or you can disarm it by unlocking the car by using the key and turning it in the drivers door to the unlock position.
Jan 27, 2010 | 1989 Nissan Maxima
Had car starter installed now the passlock light stays on. He took the key out while the vehicle was running. They disconnected the battery and hooked back up but that did not work.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the Content Theft Deterrent (CTD) armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the body control module (BCM) stores the CTD mode status in memory.
• To disarm the CTD System in arm pending mode, SECURITY indicator flashing and doors open, perform one of the following: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and start the vehicle. • To disarm the CTD System in the armed mode: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and start the vehicle. • To disarm the CTD System when activated, alarming mode. - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and start the vehicle.
Nov 04, 2009 | 2005 Chevrolet Equinox
I cant disarm my alarm
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
Feb 03, 2009 | Viper Security and Remote Start System...
Intermittent arm/disarm of Python model 560XV
this "could" be a bad ground, however, usually when these units lose ground, they activate the siren at a really low level, because they are trying to ground through the siren.
I would say to check where the antenna plugs into the main unit,(brain) but honestly, in 17 years of dealing with DEI alarms, 99.9% of these problems are due to the transmitter - it may blink the LED like it is supposed to, but that doesnt gaurantee it is sending a signal. I would recommend buying a new transmitter and programing it to the brain.
Jan 15, 2009 | DEI Python 1400XP Remote Start/Keyless...
Vehicle Parts & Accessories Logo
873 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
