Question about Cuisinart DLC-2011 PowerPrep Plus Food Processor
Cuisinart 11 cup processor
Everything is in place and locked, plugged, red light comes on but nothing happens!
  • mzpong Feb 18, 2009
    I just bought the Cuisinart 11 cup processor. I did everything according to the instruction. Everything snapped into place correctly, the lights turned on but nothing happened when I pushed the slow, fast or pulse buttons.
    Problem Solver:
  • 5 Answers
I went through the same it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Posted on Feb 06, 2008
My kitchenaid 7cup new food processor will not work. There is no light that comes on. Help!
Brand new, take it back where you got it from then, no point fiddling about endangering your guarantee.
Oct 05, 2014 | KitchenAid Food Processors
My Oster 3212 food processor will not turn on.
You have to make sure that both the bowl and the cover are locked into place. Sometimes if you wiggle it a bit, it will go into the right spot. Make sure that the outlet you are using works.
May 22, 2014 | Oster 3212SNB Food Processor
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
My cuisinart DLC-1ss will not start once plugged in.
The bowl must be locked in the correct position for the unit to turn on.
Remove the bowl, place on unit and rotate into place.
Oct 04, 2010 | Cuisinart DLC-1SS Mini Prep 2.63 Cups Food...
Food processor not working
check cover safety tab possible broken or faulty switch
Aug 29, 2017 | KitchenAid KFP740 Food Processor
When i try using it, nothing happens. i cannot
Remove the work bowl, blades, etc from off the base.
Plug the processor in and press the ON pedal down.
Use a pen to press in the rubber button on top of the base - you should hear a sound.
Now reassemble the bowl - lock the bowl in so that the handle faces front; insert blade of choice; place the tab under the feed tube of lid slightly left of center of the work bowl handle and slide the lid counter-clockwise until it clicks into place; insert pusher and make sure it locks into place.
You should be good to go again.
Sep 30, 2009 | Cuisinart Food Processors
Will not cut on
In order for the processor to work, the bowl, lid AND pusher must all be in place - if one part is out of place, it will act dead. The proper assembly varies by model #. If you call Cuisinart at 1-800-726-0190, they are very good at getting you through the proper assembly.
Sep 04, 2009 | Cuisinart Food Processors
It won't turn on
The work bowl and lid must be locked together in a specific order or else the processor will act dead. If your DFP-3 has a "tower" on the back, make sure the tab on the lid connects to this tower. If your model does not have a tower, call Cuisinart to verify the correct assembly - 1-800-726-0190
Aug 16, 2009 | Cuisinart DFP-3 Handy Prep 3 Cups Food...
My brand new Cuisinart 14 cup food processor won't turn on. All the components are locked in place and it's plugged in. Help
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DLC-5 Food Processor
Cuisinart DLC-2011 PowerPrep Plus Food Processor Logo
947 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
