Question about Acer Aspire 4720 Notebook
My touch pad has stopped working
I turned my laptop on and the touchpad has stopped working please help i have an acer (aspire 4730-4516) model jal90 and my tapping pad partially stopped working. the mouse moves but to click i am forced to use the buttons. the tapping action no longer ios working how do i fix it? please help!!!
  • 6 more comments
  • cbrake7274 May 12, 2009
    it still is not working the mose part still is but the clicking with the pad is not : (
    the buttons work and the pad wirks as a mouse but it when you try to tap on the pad, rather then using the buttons is when it is not working. do you know what i mean?
    as far as i know i do. i bought it in march and they said everything was installed. it has been working fine up until today like 3 hours ago. i have tried restarting it and shutting it down for a little while and everything... frustrating...
    am i going to lose anything that i have saved on here today if i do that? i thank you so much for you help. yes i have already tried the tool on the bottom right of the screen so i am going to try the other.
    ok i am going to try it now ill be right back to you
    that did not work either?
    would that be considered a utility download? i am sorry i am all new at this
    did not work well i thank you for all your help. i am just going to have to take it up to best buy and see if they can see whats wrong
  • Acer Master
  • 4,806 Answers
Hi there'
Hold down Fn and hit F7 to see if the touchpad reactivates.
Please post back if you have any more trouble.
Good luck and thanks for using FixYa!!
Posted on May 11, 2009
  • 5 more comments
  • Lee Hodgson
    Lee Hodgson May 12, 2009
    Hi again.
    Go to the control panel, select mouse and make sure left and right click is activated.
    Good luck
  • Lee Hodgson
    have you got the drivers and the software installed for the touchpad as this can be a common problem when double-tapping the pad
  • Lee Hodgson
    Hi again.
    Look at the bottom right hand side of the screen, if you can see a box with alittle meter that moves only when you touch the pad then thats the utility, just click on that and you will be able to adjust the touchpad properties from there.
    If that does not work then perform a system restore through all programs, accessories, system tools and them system restore and take the machine back to yesterday or the first available date you can see.
  • Lee Hodgson
    Hi again.
    If you perform a system restore (not recovery) you won't loose anything, only a system recovery does that.
  • Lee Hodgson
    Ok, go here to Acer suport, download and and install the touchpad drivers again to see if that works >>>>>>
    http://support.acer-euro.com/drivers/not...
    Good luck
  • Lee Hodgson
    yes you can get the touchpad drivers and the utility to set the sensitivity of the touchpad
  • Lee Hodgson
    Yes you have tried everything to get it working to no avail, taking it back to the shop for the engineers to look at would be a good idea now.
Touchpad buttons stopped working. movement of mouse works fine
Are the drivers installed for the touch pad? Try reinstalling the drivers or go into the setting for your touch pad and see if the buttons are disabled.
Try the link.Possibly it can help you.
What to do when your laptop touchpad stops working
Oct 26, 2015 | Acer Aspire V5-122P-0864 11.6" Touch...
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Acer Aspire 5733z-4851
My acer aspire 5551-2036 synaptics touch pad tapping function stop working. pls help. thanks.
check your touchpad settings to enable and adjust the tapping settings. if this does not work, try to reinstall your touchpad driver by downloading the latest one from the acer support web site.
Apr 21, 2011 | Acer Aspire 5100 Notebook
Aspire 5515 touchpad not working
It might be a keyboard shortcut you unintentionally pressed. On an Acer 5515 it
May 19, 2010 | Acer Aspire 5315 Notebook
Emachines e725 Touchpad Not Working
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple.
May 02, 2010 | Acer Aspire 3000 Notebook
Acer touchpad not working
Hi thre can you please check the touch pad mode? May be its disable some how. Or try to press FN+ F7 key for enable / disable touch pad. What is happend please let me know. Thanks.
Mar 18, 2010 | Acer Aspire 3680-2682 Notebook
My laptop's touchpad do not work at all. With an external mouse it's ok. I have windows seven and Ubuntu 9.10, and the pb is the same for both. My laptop is a acer aspire 5732z g Thanks.
On Acer 5732Z there is a button that disables the touch pad next to the power button [on the left]. The icon is a rectangle with a hand pointing on it.
press the button to toggle the touch pad on and off.
Feb 11, 2010 | Acer Computers & Internet
My laptop touch pad stopped working, it wont move when we click...model acer aspire 4520
Try Fn+F7 to reenable the touchpad. Might have been disabled by mistake.
Jun 30, 2009 | Acer Aspire 5920-6727 Notebook
Touch pad stopped working
I recommend you to uninstall and reinstall touchpad drivers to isolate the issue.
Press Windows key and R. Type devmgmt.msc in Run window and click on OK. Click on "+" sign beside Mice and other pointing devices in Device Manager.
Right click on Touchpad and select Uninstall.
You will be prompted to restart the computer.
Windows detects touchpad and the touchpad drivers will be reinstalled automatically.
You can also install touchpad drivers from your notebook support website.
You can reinstall the drivers from the below links:
http://support.acer-euro.com/drivers/notebook/as_5920.html
http://www.laptops-drivers.com/acer-notebooks/download-drivers-acer-aspire-5920-notebooks.html
However I suggest you to install the drivers by visiting the acer support website.
Also perform windows update.
Jun 29, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 4720 Notebook Logo
525 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
