Question about GE 28031EE1 Cordless Phone
I have a GE phone 4-handset system model 28031. It quit and the handset screen reads ''Out of Range''??? Anybody have this same problem and have found a solution. I rtied the usual unplug, remove batteries, use internal program to register the phone..
Posted on Jun 11, 2009
Handset display says "Connecting" I can't deregister. How can I get the handset to display "not registered"?
The procedures to deregister are, of course, specific
to each make and model number of cordless phone.
All of them are a LOT more involved than simply
removing the battery.
For some AT&T, VTech, Uniden, & GE model numbers
you might try the following:
For many AT&T models it is simple:
1. When the handset says "Connecting..."
enter *331734 [menu]
it will soon (chirp) and display "Not registered"
For many VTech models it is a bit more involved:
1. Start by taking off the battery compartment cover.
2. press [menu]
3. scroll up/down to "Settings"
4. enter * 7 8 9 0 #
5. if display reads "Test Base",
scroll to "Test Handset", press [select]
scroll to "next page", press [select]
6. scroll to "Register Clear?", press [select]
7. display asks "Confirm?" or "Register Clear??",
press [select]
8. display reads "Ok" (chirps), press [ off ]
9. UNPLUG THE HANDSET BATTERY
(this is why the cover is off)
10. Wait ~30 seconds, re-connect the battery &
replace the cover
11. display reads "Not Registered"
For many Uniden models:
1. Press and hold the [END] and [ # ] keys at the
same time, after a few seconds the display reads
2. "System Reset, Deregister Handset"
3. scroll to "... Base Unavailable"
press [SELECT]
4. Handset (chirps)
press [END]
5. display reads "Not Registered, Place in base..." =====================================
For some GE models:
1. press "program[mute]"
2. scroll to "Handset Setup" press "program[mute]"
3. scroll to "Deregistration" press "program[mute]"
4. scroll to "Yes" press "program[mute]"
5. display reads "Not Registered"
Once you have the handset displaying "Not Registered"
you can follow the User's Manual instructions to register
the handset.
The model number for your cordless phone is shown on
a small sticker underneath the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual if you need it.
Mar 14, 2016 | Lands Phones
GE handset 28101 will not sync with base-GE 28129
Unplug power cord from the base for ten or fifteen minutes, this is the only user level operation that you can do to try fixing the problem.
If after resetting the base still do not find the handset, then either the base or the handset is faulty.
If the base works fine with a different handset, then it is the handset.
Sep 14, 2008 | Lands Phones
How to enter menu
Called GE Thomson @800-448-0329
Feb 24, 2010 | Uniden Cordless Phone
ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
GE cordless phone no longer will make or accept calls
try new battery. that happened to me this weekend. i put the battery fro the second handset i dont use in it and everythings fine.
Jan 19, 2009 | Uniden Cordless Phone
Registering handset
If all else fails, read the instructions.
"4. Place the handset in the base cradle. The charge/in use indicator turns on, verifying the battery is charging. The unit will take 20 seconds to register and verify its security code. READY shows in the handset’s display."
Dec 12, 2008 | GE 25922 Cordless Phone
I need a manual
Thompson makes phones under the GE label. model numbers end with EE1 EE2 EE3 EE4 which indicate the total number of handsets in the package you bought, so the manual for EE2 EE3 EE4 are the same thing. here is a link to the EE3 manual:
http://www.home-electronics.net/ge/pc/IB/28031EE3_IB.pdf
Dec 01, 2008 | Uniden Cordless Phone
User guide for the GE 28031 series 5.8 GHz cordless phone
http://www.home-electronics.net/ge/pc/IB/28031EE2_IB.pdf
This link is the user manual for the GE 28031 5.8 gig cordless phone with answering system
Dec 01, 2007 | Uniden Cordless Phone
GE dect 6.0 cordless phone bought at walmart
We had the same problem.
"Our phones worked fine for two weeks but now you can not dial out
and when someone calls us they can't hear we say. The line still works
fine with our old phone1.gif."
To fix the problem, I simply unplugged the base AC plug from the outlet, waited about 15 seconds, and then plugged it back in. Both handsets said searching on the display and then handset names returned to the display as originally programmed. The phones returned to operation as normal.
Devo
Nov 14, 2007 | GE 28111 Cordless Phone
GE 28031EE1 Cordless Phone Logo
306 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
